Old 06-30-2014, 09:53 PM   #1
Can I run a 2nd battery only when needed?
I've got dual batteries now, except the dealer installed different guage and length of wire to both...so I'm going to make it equal.
if I go on a shorter trip, can I run with only one battery, then bring along a second only when needed? I know that technically this will work, but I'm asking if it will get one or both batteries out of balance to use them apart in some situations and together in others.
Thanks!
steamboatscott is offline   Reply With Quote
Old 07-01-2014, 07:42 AM   #2
rburns4147's Avatar
Thanks!
Are you talking about having two batteries for engine starting or for powering the lights and other electrical components in your RV?
I am thinking that if you have two batteries to power your RV, it is better to have them both hooked up all the time. I think that if you would use one most of the time then only use the second one on longer trips, the more used battery would pull down the stronger battery, making both not last as long. I think they would both last longer if you put both in and used them as a set.
Why would you want to leave one at home on short trips? To save weight?
Ron and Elizabeth
2014 Rockwood 8285-IKWS
2006 Ford F250 6.0 Diesel 4x4
rburns4147 is offline   Reply With Quote
Old 07-01-2014, 08:16 AM   #3
Yes it would be for powering lights/furnace fan/etc on my popup. I'm trying to save weight, leaving the 2nd battery behind for shorter trips and bringing more toys instead.
I would trickle charge the second battery when not in use, but it would still have less discharge cycles. I could even switch batteries each trip.
Old 07-01-2014, 09:02 AM   #4
SKnight's Avatar
Set it up according to this photo, then make one cable long enough that when the extra battery is out you can just attach it to the single battery.
Old 07-01-2014, 12:36 PM   #5
Thanks @SKnight. I'm assuming I should have a fuse between the positive lead of the two batteries (in addition to the poistive lead comign into the battery bank) to disconnect when not in use/not charging so they don't constantly charge/balance each other out?
Old 07-01-2014, 02:03 PM   #6
Herk7769's Avatar
Another vote for both all the time.
Properly paired and connected, your batteries will work half as hard and last twice as long as a single one.
When connected properly they will charge and discharge equally and never be unbalanced. Only if you try what you suggested, will your batteries get out of balance and one of your batteries (closest to the charge/discharge connection) will fail well before the other one.
File Type: pdf How to correctly interconnect multiple batteries to form one larger bank.pdf (106.1 KB, 22 views)
HAM CALLSIGN - KC3FFW
Old 07-01-2014, 02:26 PM   #7
Toby's Avatar
Don't mean to hijack but how would you work it if you have one brand new battery and one used battery (one battery had to go with the old camper and now I have a new one). Was thinking about putting in a switch to use independently but how I had them before is similar to the drawing above.
2018 Ford F250
2019 Arctic Wolf F295QSL8
Toby is offline   Reply With Quote
Old 07-01-2014, 02:31 PM   #8
Herk7769's Avatar
I would buy a new battery that matched the one in the new camper and connect it as shown.
The old battery would be dedicated to a back up sump pump in the basement or some other use.
If you can NOT do that; buy a 2 position battery switch and NEVER use the "BOTH" position. Run the positive from each battery to its own terminal and charge/discharge each one separately.
Old 07-01-2014, 02:52 PM   #9
Toby's Avatar
OK. That's essentially what I was planning on doing. I even have a switch similar to the one you show. Thanks. Then again, a new battery is only $90 and the last setup worked well so maybe I'll splurge and sell the old battery.
2018 Ford F250
Old 07-01-2014, 03:04 PM   #10
Herk7769's Avatar
Toby, I would do it before I put too many charge/discharge cycles on the one you have. The longer you wait, the more "out of sync" the two batteries will be.
battery
