Old 04-25-2016, 02:05 PM   #11
WolfWhistle's Avatar
X10 on the cheater plug. 1) the ground will usually be too high (in ohms) to he of any value.
2) it will not offer more personal safety, if anything it will be worse.
3) the only situation where a generator must be grounded is when it feeds a building (per the NEC)
I would not bother to use my EMS on genset, but if you insist make and usevthe "plug". I would plug it in at the genset: not to any 'ole outlet.
WW
Hyper diaper 29HFS = 2015
2017 F-250 4x4 6.2L Gas
Old 04-25-2016, 05:24 PM   #12
Generator ground
I purchased a EMS PROGRESSIVE
GENERATOR PLUG TO SOLVE THIS PROBLEM...
Louisiana Irishman is offline   Reply With Quote
Old 04-26-2016, 06:14 PM   #13
Much simpler to take your surge/open ground/neutral off line. If you use/forget and use the same plug with neutral and ground tied together on/in a defective post and touch the aluminum siding not good. Some generators have a frame ground that can be tied to the TT and 4 foot rod driven into the ground - too much work, take the surge protector off line (AC may drop the the low voltage trip anyhow).
DJsFolly
D. J. Schuler is offline   Reply With Quote
Old 05-04-2016, 05:52 PM   #14
As a follow-up, I finally had a chance to hook my Honda 1000 generator up to my coachman clipper. The interior outlets ran just fine off of the generator. So it looks like the ground issue doesn't affect me in terms of being able to power the 110 things inside the clipper.
hbidlack is offline   Reply With Quote
Old 05-04-2016, 05:54 PM   #15
TURBS's Avatar
You must not have a progressive industries unit?
Old 05-04-2016, 05:57 PM   #16
Flybob's Avatar
Originally Posted by Rick_Geneseo View Post
The reason to ground a generator is to discharge static. I seem to remember every Army generator came with 3-3foot ground rod sections and to complete the ground for whatever you were powering.
Yes but only when they were new. After the first usage, the ground rod was gone. There must be thousands of ground rods in the ground all around the world.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 05-05-2016, 09:06 AM   #17
We used to drive the rods... which if in sand read nearly infinity for ground; but if in hard dirt we would couldn't get them very deep.. So we cut them off. Naturally we couldn't get the out so they were left.
WW
generator
