Old 04-25-2016, 08:29 AM   #1
Can I/Should I ground my generator?
I have a Honda EU 1000 I generator. We just bought a coaching clipper 17FQ. We expect to do a lot of boondocking, so we upgraded the batteries to 2 Trojan 145 batts. As I understand it, the 110 outlets in the trailer will operate only on shore power or when the generator is plugged in.
My surge protector, when plugged into the generator, shows an open ground. There is a grounding screw on the front of the generator panel, or at least what I think looks like a grounding screw.
Should I ground the generator when operating out in a dry camping environment? If so, I would be very grateful for your advice on how to do that correctly.
Many thanks from a complete rookie.
Hal
hbidlack is offline   Reply With Quote
Old 04-25-2016, 08:39 AM   #2
rsdata's Avatar
If you are only using portable cords plugged into the generator you need to do nothing. Sticking a ground rod into the dirt will not add any safety measure.
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
Old 04-25-2016, 08:43 AM   #3
TURBS's Avatar
You need to make a neutral bonded plug.
Then you'll plug it into one of the outlets.
2008 2500hd Duramax
2015 Columbus 320RS
2016 nights camped "0"
2015 nights camped "34"
Old 04-25-2016, 08:45 AM   #4
SeaDog's Avatar
Not sure why you would be seeing an open most generators make a complete circuit. The grounding lug is used when two generators are hooked in parallel Why are you running a surge protector with your generator I doubt you could get a surge large enough to cause any problems before the generator would trip.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 04-25-2016, 08:48 AM   #5
Phat Phrog Stunt Crew
elind's Avatar
2008 2500hd Duramax
2015 Columbus 320RS
That will trick the surge protector to think the generator is grounded. Some surge protectors are hardwired inside the RV.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 04-25-2016, 09:08 AM   #6
elind's Avatar
I like my surge protector inline when I run two Hondas because when one runs out of gas with the AC on the S/P shuts down because of the low voltage.
2014 Wildcat 327ck
Old 04-25-2016, 12:15 PM   #7
The reason to ground a generator is to discharge static. I seem to remember every Army generator came with 3-3foot ground rod sections and to complete the ground for whatever you were powering.
Rick_Geneseo is offline   Reply With Quote
Old 04-25-2016, 12:16 PM   #8
TURBS's Avatar
Grounding the generator to the earth will not fix his issue.
Only a neutral bonded plug will.
2008 2500hd Duramax
2015 Columbus 320RS
Old 04-25-2016, 12:23 PM   #9
Agree with Turbs. The surge protector is not sensing the ground or neutral. It is sensing that there is no voltage between the hot and ground and assuming that is an open ground since if your were plugged into your house or a power pedestal there would be 120 volts between the hot and neutral and between the hot and ground. RVs do not connect the two for reasons that have been stated in this thread numerous times.
Make a plug like Turbs has indicated and it should solve your problem. In either case it won't hurt anything. Just plug it into one of the duplex outlets (with the cover in place on the plug...of course.)
2015 335DS
ScottBrownstein is offline   Reply With Quote
Old 04-25-2016, 01:29 PM   #10
Blog: RVroadtripper.com
hbillsmith's Avatar
Link to article explaining how to build the adapter plug
Maxxis 235/80/16E; AirBags w/AirLift 1 wireless compr; 4-Fold Tonneau; 6000# Dexters; mor/Ryde Rubber Pinbox & CRE3000 w/HD Wetbolts; Andersen UltimateII Aluminum 5erhitch on Reese Flipball w/Curt 4" offset ball; LCI Ground Control3 4pt+2pt Elec.Rear stabilizers; 3 Slidecovers; King Dishtailgater; 10ft. Portabote w/5hp Outboard; Dual A/C; Furrion48 Rearcam; Champion 3100 Inverter w/DIY Extended Run
hbillsmith is offline   Reply With Quote
generator
