Old 10-05-2011, 09:27 PM   #1
Kmair1's Avatar
Can you connect shore power when the battery is disconnected?
I'm sure my battery is fried and I want to take it in for testing. When the battery is disconnected can I still attach my TT to shore power or will this harm my converter/inverter in any way?
2016 Flagstaff 25FKS
2014 VW Touareg R-Line TDI
2011 Rockwood 2608SS (Gone)
2006 Infiniti QX56 (Gone)
Kenny, Annie, and Brock (The Labradoodle)
Kmair1 is offline   Reply With Quote
Old 10-05-2011, 09:37 PM   #2
TURBS's Avatar
you should only have a convertor.
yes you can plug it in to shore power without battery just minimize 12 volt usage but it will work just fine . the convertors only real purpose is to charge the battery and supplement the battery .
Old 10-05-2011, 10:06 PM   #3
frankm's Avatar
I called WFCO Cheng USA (the makers of the converter in our Rockwood) Tech Support asking the exact question. No problem was their answer but as f1100turbo said, with one caveat: if you have a slide-out don't extend or retract it. The slide-out 12V motor can easily fry the converter with out a good battery helping things out. Something about too high amperage. If you find yourself with the slide-out extended and a dead or no battery their recommendation was to bring the slide out in manually.
Frank & Rita M
2016 Ford F-150 XLT Ecoboost
2017 Rockwood 2703WS
frankm is offline   Reply With Quote
Old 10-05-2011, 10:09 PM   #4
TURBS's Avatar
to add to my post and to what frankm said
I wouldn't use anything more than lights if I had to.
Old 10-05-2011, 10:23 PM   #5
acadianbob's Avatar
THAT'S interesting! Never thought about the slide cooking it. . . .
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 10-05-2011, 10:34 PM   #6
TURBS's Avatar
most certainly ! the unit will over heat and or the cheap 50 cent fan will give up the ghost and
man I have used that blow up twice today I am at my limit I think !
Old 10-06-2011, 06:57 AM   #7
Not sure if you're talking about taking the TT to the dealer with a bad battery, but if you transport with a bad battery you have no breakway brakes.
Len & Cheri is offline   Reply With Quote
Old 10-06-2011, 07:30 AM   #8
TURBS's Avatar
I think he was removing the battery and leaving camper at home plugged into shore power.
Old 10-06-2011, 09:11 AM   #9
Most likely, just throwing a little caution out there
battery
