Old 07-21-2018, 11:11 AM   #1
Can you have two converters?
Looking ino replacing my 50 amp wfco POS with a progressive dynamics converter that will actually go into bulk mode and was wondering if I could put two 50 amp converters in instead of a single 80 amp.
We plan on winter camping a lot. Half of which will be boondocking so all my pipe and tank heaters are 12v to the tune of 65 amps of specified amperage ( I havenít installed everything yet). I understand everything will be cylicing on and off and not everything will be cycled on at the same time.
I would like to have faster battery charging and redundancy with two separate converters.
Wire size is not an issue. Between the converter/ fuse box to the batteries is 1/0 welding cable and my 6v batteries are all wired togeather with the same cable. ( itís a 30foot run)
D
quicky06 is offline   Reply With Quote
Old 07-21-2018, 02:53 PM   #2
Duckogram's Avatar
Sure you can. My Jayco came with two 45’s. Just like a 50amp 120v service is really two 50amp 120v feeds, the two converters would service different loads. The issue would be splitting the feeds on the power distribution panel. One solution would be two panels.
ILB
Old 07-21-2018, 03:00 PM   #3
BandJCarm's Avatar
Call the guys at Bestconverter.com and discuss with them. They are very good and very helpful.
FROG AR-0019-242
BandJCarm is offline   Reply With Quote
Old 07-21-2018, 03:07 PM   #4
Originally Posted by Duckogram View Post
Sure you can. My Jayco came with two 45ís. Just like a 50amp 120v service is really two 50amp 120v feeds, the two converters would service different loads. The issue would be splitting the feeds on the power distribution panel. One solution would be two panels.
I know I can have two on separate circuits. What I was interested I was having two on a single dc circuit.
I would like to mount both of them behind my panel ( there is a large void need the counter) then wire them to a bus bar then to the power distribution panel.
Wiring them separately would be rather simple using a transfer switch.
Old 07-21-2018, 03:16 PM   #5
Duckogram's Avatar
If you are only using one it seems that all you would be accomplishing is that you would have a “prewired” spare that you could bring online with the flip of a switch.
ILB
Old 07-21-2018, 03:26 PM   #6
If you are only using one it seems that all you would be accomplishing is that you would have a ďprewiredĒ spare that you could bring online with the flip of a switch.
I would like to run both at the same time.
2 50 amp converters give me more power than a 80 amp converter.
I just donít know if this would cause issues or not.
Old 07-21-2018, 03:42 PM   #7
Head Rambler
As said above call Best Converter.
I'm afraid that they'd buck each other especially since they're not matched units. I may be wrong about that, and you may be able to bias one so that it only kicks in when the amp load on the other converter gets to a certain load or can't keep up.
Gotta go campin!
Old 07-21-2018, 04:02 PM   #8
bubbles's Avatar
What happens when our RV two 12 batteries are connected in parallel?
Old 07-21-2018, 04:03 PM   #9
BandJCarm's Avatar
You get 12v with more amps.
FROG AR-0019-242
Old 07-21-2018, 04:10 PM   #10
Head Rambler
Completely different situation. The converters are more than power supplies, they're also battery chargers and there's where the problem lies.
If they were just power supplies then connecting them in parallel isn't a problem at all.
Gotta go campin!
converter
