Old 05-06-2012, 02:12 PM   #11
Looks like it was a short Took apart the breaker panel, and it looks like in all the shakin, one of the GND bare copper wires had shook enough over to short against one of the mains. Once I re-organized the wiring in there, everything is peaches and rainbows!
Thanks for the help all.
1997 FR Sierra 30RKS
2004 GMC Sierra 3500 Dually CCLB
DageonYar is offline   Reply With Quote
Old 05-06-2012, 02:13 PM   #12
TURBS's Avatar
does your outlet look like this ? Click image for larger version
if not then its only 15 amp outlet .
Old 05-06-2012, 02:18 PM   #13
I think I would wrap the ground wires with black tape at least where there might be even a remote chance of them moving again. I have seen professional electricians wrap the back of outlets to prevent the possibility of shorting and shocking. That might be an easier solution.
Old 05-06-2012, 04:54 PM   #14
Originally Posted by f1100turbo View Post
does your outlet look like this ? Attachment 13322
Yes, that's the outlets I installed. And it runs 10/3 from the main breaker to the garage. I made sure I would have enough juice since I run my welder from there as well.
Cheers -
Old 05-06-2012, 05:38 PM   #15
TURBS's Avatar
Cheers -
if you ran 10/3 then you could just install the normal 30 amp outlet your camper requires . 10/3 is 30 amp rated so why use the adapter
Old 05-06-2012, 06:07 PM   #16
Jack of All Trades
RJHuser's Avatar
Most welders are 240VAC not 120 VAC, so be very careful what you are doing. 240VAC will destroy the electronics and appliances in the trailer.
Also 10/3 is used for 240 VAC circuits. 10/2(with ground) is used for 120 VAC circuits.
Do you have a single or double breaker on this circuit? Single breaker is 120 VAC double breaker is 240 VAC.
Again, be very careful what you are feeding the trailer with!
Rick & Debbie; Brandy & Schnoodle (Dexter & Fritz R.I.P.) the Doxie "Kids"
2015 Jayco Pinnacle 36RSQS 5'er
2018 GMC Sierra Denali 3500HD, 6.6L Diesel Dually; B&W Companion 5'er hitch
ScanGauge, TST 507 TPMS
RJHuser is offline   Reply With Quote
Old 05-09-2012, 09:56 PM   #17
mtusrsmith's Avatar
One thing to consider is whether your normal 20A receptacle in your house is protected from ground fault by a GFI circuit breaker in the breaker panel in your house. Does the breaker that tripped have a 'test' button on it? If so, it is a GFI breaker and you may have a ground fault problem in your trailer. I understand that it worked fine before--see my recent posts regarding my camper that is only three months old and having (possibly) a similar issue.
mtusrsmith is offline   Reply With Quote
Old 05-09-2012, 10:22 PM   #18
Herk7769's Avatar
This is so true. More than one crying camper here who managed to fry every bit of electronics in his camper this way.
He did say it worked last year, so I think he is good to go now.
HAM CALLSIGN - KC3FFW
Old 05-10-2012, 12:54 AM   #19
Terier's Avatar
Just got my 5'ver out of being mothballed for the winter (I know.. late... but we had twins last week lol). Everything seems to work fine when running on the 12V and gas. However, when I try to plug in the 110V line to my house line, it trips the breaker in the house (20A). I have tried turning off all the breakers in the trailer, and turned off all appliances/lights in the trailer. Still happens. Something is shorting out the main line coming in I'm guessing. Looking for some help on where to start troubleshooting.
TIA.
Twins as in new members of the family? Boys? Girls? One of each? Not sure how this news was missed but congratulations!
Old 05-10-2012, 08:57 AM   #20
If every thing checks out per the previous suggestions, what else is on that circuit ? Maybe something as simple as too much total draw on the circuit. For example - perhaps you have a new space heater plugged in that you didn't have last year. Could also be a "weak" 20 amp breaker in your house distribution panel, which is a simple replacement job.
...VTX-Al
VTX Al is offline   Reply With Quote
breaker
