Old 09-09-2015, 07:55 PM   #21
Blackhat6mike's Avatar
I installed two 110 vac/USB wall plugs in the TT last year. Didn't try to plug a USB device into them till March this year. 110 vac worked good, but USB plugs were bent inside and would not allow a plug in. When I straightened out the USB ports and plugged in, the whole outlet started smoking. I hit the inverter off switch in time to avoid a sure enough fire. Re-installed the original outlet and in works fine now. I'll just do without a USB port.
Aviator Wright Flyer #1919
Army Pathfinder Vietnam, 3 tours
DAV, MOPH, VFW, NRA, 1stCav. ABN
Blackhat6mike is offline   Reply With Quote
Old 09-09-2015, 08:07 PM   #22
Flybob's Avatar
The cheap switching regulator wall warts do not seem to like inverter output even pure sine wave. If you are using solar, you are probably better off using a 12V to USB converter. I have several WW that have non polarized plugs that work great plugged in in one direction but overheats when plugged in the other direction.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 09-10-2015, 04:49 AM   #23
RPAspey's Avatar
You might be onto something. We've used this set up for a bunch of trips, never before with an iPad. Maybe with just a phone, the load vs plug polarization was ok. But this time, the added load of the iPad and possibly plugged in differently could have caused the problem.
It's weird as we've had other wall-warts, none have gotten warm. Im gonna keep an eye on the polarization from now on.
BTW, I just received an 4 USB port, 8 amp total (2 amp each port) lighter style charger. That should do it!
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
