Old 10-12-2015, 11:41 AM   #1
Ceiling Lighting Problem - 2011 Berkshire 390RB
The darned lights won't come on. Tested the circuit to the switch and have power. The lights light when I bypass the switch. So, I think, it's the switch. To double-check, I exchange the bedroom switch w/the living room switch. The LR switch works fine in the bedroom, but the bedroom switch won't work the lights in the LR. To further confound me, we had the same problem last year, but the lights started working again after we decided (but before we received) dealer assistance. Any thoughts on possible course of action?
helferdm is offline   Reply With Quote
Old 10-12-2015, 11:46 AM   #2
Ddubya's Avatar
Pull the fixture down and pull the wires from the ceiling far enough to see the wiring connections. You may have a bad wire nut connection.
I had this happen last year.
Ddubya is offline   Reply With Quote
Old 10-12-2015, 11:49 AM   #3
Sounds logical. Any light or is there a first one in the chain?
Old 10-12-2015, 11:52 AM   #4
Ddubya's Avatar
I would start with the closest one to the switch. They are wired in series but you never know which one is the first.
Old 10-12-2015, 02:53 PM   #5
No joy, I'm afraid. Two wires coming in, split to a light on the right and to the one on the left. Nothing. They get power with the switch out of the circuit, so it doesn't seem like it's the series after the switch. Maybe a poor ground?
Old 10-12-2015, 03:50 PM   #6
Ddubya's Avatar
Ok, the lights are 12volts DC so there are only two wires. I would check at the first light to see if you have voltage coming from the switch.. I think you said that there was voltage at the switch.
It could still be a bad or corroded connection. They use the little crimp connectors which if not properly crimped can arc and create a bad connection. Wiggle the connections, sometimes that will indicate the bad crimp.
2011, berkshire, ceiling light
