Old 07-01-2015, 09:16 PM   #1
Ceiling Lights Not Working but Floor Do Work
Am prepping my 2014 Rockwood HW 276 for travel this weekend after not using it for almost a year. Am connected to garage 110 power but unable to have ceiling lights work while floor lights, audio, microwave and ceiling fan do work. Am a newbie and would appreciate any advice. Local dealership quite unhelpful.
willmerget is offline   Reply With Quote
Old 07-01-2015, 09:25 PM   #2
clr
I would check the condition of your battery first. Unplug the 120v so that you are not reading the output of the converter and see what the battery monitor has to say about the condition of the charge of your battery. A large ceiling fan and microwave work directly off of the AC and not the DC from the battery. The ceiling lights and most of the lights in your camper work off of the DC. If the battery is OK I would begin checking the DC fuses.
clr is offline   Reply With Quote
Old 07-01-2015, 09:36 PM   #3
Done with this
Is the master light switch turned on? It should be a switch probably by the entrance door...
I'm a little too truthful, I guess.
Y'all have fun in "Fantasy Land".
4mula1fan is offline   Reply With Quote
Old 07-01-2015, 11:40 PM   #4
Ceiling Lights not Working
Thanks for the battery condition suggestion. I do not see that my HW has a battery monitor, however, am trickle charging the battery overnight. If it does not take a charge then will replace. However, it is an two year old Interstate that I thought would have had greater life. In the future I will want to turn off circuit breakers when the unit is stored and also try to check for a possible power drain.
I am aware of the master on-off switch at the entry door. If battery is not an issue then testing this switch and possibly replacing is the next step.
Question: Why would my floor lights turn on but not the ceiling lights? Is one set AC and the other DC?
I appreciate your help, guys.
Old 07-02-2015, 12:09 AM   #5
bikendan's Avatar
The OP has a popup.
Should be a plunger switch that is activated when you flip up the sink section.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 07-02-2015, 07:21 AM   #6
Done with this
Because the ceiling lights lay on the canvas when the camper is in the down position.
Old 07-02-2015, 02:52 PM   #7
bbbeebop's Avatar
Check to see if your plug at the roof line above one of your roof uprights is plugged in
bbbeebop is offline   Reply With Quote
Old 07-02-2015, 03:48 PM   #8
Crockett's Avatar
Originally Posted by bikendan View Post
The OP has a popup.
x2...this switch fails a lot...
Crockett is offline   Reply With Quote
Old 07-02-2015, 04:06 PM   #9
Some of my lights turn on from different locations. I got my lights on and found other switchs would turn them off.
Myrle is offline   Reply With Quote
Old 07-02-2015, 05:17 PM   #10
Crockett's Avatar
the plunger switch resembles a standard switch on some models...make sure you replace with a momentary switch..
light
