06-21-2016, 03:49 PM
#21
Blog: RVroadtripper.com
I have had the Champion 3100 Inverter manual pull for 3 years now. It's starts easy on the first pull. Thought about selling it and getting an electric start until I ran into a fellow camper whose internal battery for the electric start had died. It still has a manual pull you can use but you have to remove the back cover to do a manual choke. Not a big deal really, it just wasn't evident until we read the manual.
I'm keeping my 3100 manual start because I just found out I can spend about $70 and add the option to use my boats Yamaha 6gal tank as an Extended run option. I've always been concerned about pouring gas into the top built-in tank while the generator is hot and with an extended run, I won't need to do that. With a 6 gal tank I'll now be able to run 24 hours when I camp at Quartzite. Besides, I always have my 6gal tank with me as I carry a 10ft. Porta-boat mounted under the fifth-wheel.
Maxxis 235/80/16E; AirBags w/AirLift1; mor/Ryde Rubber Pinbox; Andersen UltimateII Alum. 5erhitch on Reese Flipball w/Curt 4" offset; LCI Ground Control3; King Dishtailgater; Traveling with 10' Portabote;
06-22-2016, 04:13 PM
#22
Broncorick
From what I can tell, the sale is for the 2000 watt, and not that good a price, $450. Also hear the champs are a bit noisy? Have a 3500wt champ that was given to me , need to clean carb to get running. Will let you know how loud it is soon!
P.S. I all so am a neeeubeeee !!
2016 EVO 280
06-22-2016, 04:54 PM
#23
450 is less than half the price of the Honda or yahama. It's a great price for the inverter generator
You can buy the remote 3100 champion for 849 or the non remote for 749.
These generators are rated the same in decibels as the Honda. I can't speak to issues starting them because I have never had a problem with either of mine
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
06-22-2016, 05:55 PM
#24
2016 EVO 280
Yes, the Champion 3500 watt generator is going to be noisy. It is an open frame generator not an inverter model. The Champ 2000 inverter runs at 53db, the Champ 3500 open frame runs at 68db.
2007 Surveyor SV230 - 200 Watts Solar/MPPT Controller - 220 AH Battery Bank (Two-GC2) - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre with Tow Package
Boon Docking 99% of the time.
06-22-2016, 08:55 PM
#25
Left Coast
Wait till your 75 and tell us that....
Sent from my XT1585 using Tapatalk
06-23-2016, 12:02 PM
#26
My 2400 Watt Westinghouse runs the 13.5 btu fine. The I consider a larger generator but I wanted something I could carry around like a suitcase and fit in the front compartment of my little 2104. See the video.
https://youtu.be/mfI5elwd5dg
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
06-23-2016, 12:19 PM
#27
Left Coast
Good video
06-23-2016, 12:42 PM
#28
Thank you I just finished using it for a week up in Dixie National Forest Utah and it did a good job
USMC 68 -70
06-26-2016, 02:34 PM
#29
Lost power at our house and needed to run the Generator anyway hooked it up to our refrigerator and freezer ran for about an hour on eco mode with no problem started first pull.
Think about things before you do them make life easier not harder.
06-30-2016, 12:03 PM
#30
I have a 4kw harbor freight and put on the front of trailor. Mounted it on a Stromburg Carlson front trailor mount. I leave it there and run it. Noisey bui I don't hear it from inside. Neighbors do. Works well starts easy and runs 8 he on tank. I also added hard start kit to a.c. and generator adaptor to 50 amp plug.
06-30-2016, 12:47 PM
#31
Ah... so you are That Guy!!
Scott and Liz - Southern NM
2007 Chevy 2500HD Duramax
06-30-2016, 12:49 PM
#32
Left Coast
Got a locking gas cap?
06-30-2016, 12:59 PM
#33
Many campgrounds prohibit these type of generators for a reason. As others have stated, I woulnd't leave that alone for very long. Generators like that tend to have wires or plugs removed
