Old 06-20-2016, 11:30 AM   #1
Champion 2800 watt generator
I am interested in buying the Champion 2800 watt generator for my Roo 23IKSS. I like this generator as it will have enough power to run my A/C and is more cost effective than 2 - 2000 watt generators. The down side is that the generator weighs about 100lbs.
For those of you who are using this generator how do get it in and out of your truck? Do you use a ramp or multiple people to get it into the bed. I have not seen this model locally that I could try to lift.
2015 Rockwood Roo 23IKSS
2015 GMC Sierra 1500
Archicamper is offline   Reply With Quote
Old 06-20-2016, 11:35 AM   #2
TURBS's Avatar
Engine hoist is what I use.
Cheap one from harbor freight will do.
Sent from my SCH-R530U using Tapatalk
Old 06-20-2016, 12:01 PM   #3
not sure about weight, but FYI, i got a flyer from Cabelas this weekend and they will be on sale for thier 4th of July sale. Ad is at home.. but i think they are 25% off when the sale begins. Will check when I get home tonight
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 06-20-2016, 12:12 PM   #4
D_B Travelers's Avatar
You probably already figured this out, but a 2800 will give you 23 Amps, where two tethered 2,200's will give you 35 Amps. Just cannot run your AC and attempt to microwave something at the same time. How quiet are the Champion units? I don't remember if they are quiet or not. The noisy ones will get real old, real quick.
I used to have a Troy-Bilt 6200 generator, which weighed 250#! It was a struggle to get it into my truck, AND it was noisy. AND it was thirsty! I built a sound enclosure for it to use at a NASCAR event and it was still NOISY! Sold it and bought two of the Ryobi i2200 inverters which are within 1-2 db. of Hondas. You can stand right next to them and carry on a normal conversation. I carry both Ryobi i2200 units with a tether cable if I intend to camp not in a park; just can't use my second A/C. On longer road trips I carry just one unit with a 5 gallon gas can in case I have to camp in a road side park or Walmart for the night. One will run the 15KA/C unit for the night and power the TV/Satellite.
D_B Travelers - 8 nights in 2018, 58 nights in 2017. [U]1st love: 2014 TT WJ3001w, now 2016 40' FW SOB, 2015 GMC 3500HD CC DRW Duramax, TST 507rv TPMS.
"Happiness? A good meal, a good cigar and a good woman - or a bad woman; it depends on how much happiness you can handle."
George Burns (1896 – 1996)
D_B Travelers is offline   Reply With Quote
Old 06-20-2016, 03:45 PM   #5
You might have a problem trying to run a 13.5k AC with a 2800 watt genny. It may not be enough to turn the rotor at high head pressure.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 06-20-2016, 04:04 PM   #6
Only way to know if connect to shore power and put an amp meter on the leads. Per a site that sells the Dometic AC, the 15K only pulls about 12.4 to 13.2 compressor Amps. I can run my 15K A/C using a single Ryobi i2200. Can't run much else except the LED trailer lights, but that is okay in a pinch. Seems to start with no issues, even after running for a while.
Old 06-20-2016, 04:06 PM   #7
Champion 2800 would not run my Dometic 13.5.
bshort is offline   Reply With Quote
Old 06-20-2016, 04:15 PM   #8
TURBS's Avatar
Dometic recommends a minimum of 2500 "running" watts just for the a/c
90 degrees and humid my 15k draws 14 amps.
Remember the converter is a constant draw of 2-8 amps
Old 06-20-2016, 04:18 PM   #9
bshort, you might want to put an amp meter on it to see if it is drawing more than factory specs. The Champion should be putting out 23 Amps at 120 volts.
Old 06-20-2016, 04:25 PM   #10
Just got the Champion 2800 (3100 startup) watt generator from Costco. It runs the Coleman 15k a/c just fine along with the refrigerator in my 2014 flagstaff. It will start the a/c even when in economy mode. I am happy with the noise level as it is a LOT quieter than the Generac 2000 I bought and returned to Costco last summer. All in all very happy with it so far.
cub22908 is offline   Reply With Quote
280, generator
