Old 09-27-2016, 03:32 PM   #1
Champion inverter differences?
Dose anyone know for certain... whether the Champion 3500 inverter genny that Cabela's & CW sells is really 100 watts more than the 3400 inverter genny sold everywhere else?
I'd have to seriously doubt that the actual gennys are different, just branded differently. I sent an email to Champion and received no response.
I'm looking for more than a guess.
ID:	121447   Click image for larger version
2016 Flagstaff 8529IKBS Diamond Package 5th Wheel
Ford F-Series SCREW 4x4
TST Tire Monitor - Sinemate 3500w Gen.
2016 Nights Camped = 46
Old 09-27-2016, 04:06 PM   #2
I got the 3400w 100261i just a few weeks ago, from Champion Inverter Generators
$997.77 total, free shipping, no tax,.... in my searching I saw that same question asked on the Champion website, the Champion techs answer is this.... "The only difference between these two units is one model has a slightly more conservative, under-rated wattage output displayed on the unit and packaging."..... you can see his answer at the link below,.... its below the three reviews, the 5th question down, asked by BillJ,..... so they are the same machine, just a little different labeling, his answer says the 3400 is a conservative and UNDER-RATED figure, so it must be closer to or actually a real 3500,.... the link above has the best price I could find anywhere,...
3400W Wireless Remote Start Inverter Generator - Champion Power Equipment
fella10 is offline   Reply With Quote
Old 09-27-2016, 04:36 PM   #3
Thanks fella10,
I kind of figured. Glad to see them claim the 3400 is slightly under-rated on the packaging only. I agree with your assessment that the 3400 must be close/actually a 3500 watt model.
Old 09-28-2016, 07:37 AM   #4
Herk7769's Avatar
Just remember that the noise db scale is logarithmic and not linear.
For every 3db of sound difference means twice as loud as the lower number.
A generator that has a 70db sound rating is 10 times louder than one with a 60db rating, for example.
Worse yet, a 20db difference is 100 times louder.
HAM CALLSIGN - KC3FFW
Old 09-28-2016, 08:44 AM   #5
I don't get your point,
you appear to be warning that those Champions are too loud,
those big 3400w&3500w Champions are rated 59dB
the little 2000w Honda is rated 59dB,
have you ever warned anyone that a small Honda is too loud?
Quiet Generators - What is the Quietest Portable Generator?
Old 09-28-2016, 08:53 AM   #6
3 db when referring to sound is not twice as loud, when referring to "power" then it is twice the power. 3 db is about 1.6 times louder. Another consideration is the distance from the generator when the sound measurement was taken. Obviously being 15 feet away is going to make a big difference.
Brewhedd is offline   Reply With Quote
Old 09-28-2016, 09:00 AM   #7
Lou, thanks for your information. You always have good advice and your comments about logarithmic -vs- linear are spot on.
However...
This thread is about nothing more than whether the two generators (3400/3500 both built by Champion) are the exact, same generator... just with different branding.
I believe we've established they are and that both are actually 3500 watt.
Which brings me to the point I was aiming for...
No need to spend extra dollars for the specially (or specifically) branded 3500 watt model at Cabela's or Campers World when the less expensive 3400 watt branded generator is exactly the same machine.
Old 09-28-2016, 11:59 AM   #8
I think my previous post(#5) may have come across more harsh than intended,....... its become a regular thing here, that whenever any generator is mentioned, the Honda choir comes out of the woodwork to demean anything that isn't a Honda,... I know you never mentioned a brand, but your photo is a Honda graph, so I assumed you had it in mind and weren't aware of the dB rating of the Champions and that its the very same as the small Honda,..... which of course, is the gold standard of all generators and no one would ever say its too loud,..... so, if my post #5 seems rude or disrespectful, I do apologize, that was not my intent,......
Old 09-28-2016, 12:42 PM   #9
Originally Posted by boondocking View Post
They both have the same power output. The difference is the 3400 is a pull start and the 3500 is a remote start.
Not true on the remote start.
Both have it available and if you look closely at the photos it shows remote start capability on the side of both.
My photos were a little misleading, in that they were simply internet snags and the web site where I grabbed the 3400 photo shows a remote start button separately where the 3500 doesn't. But even that is bass ackwards from what you said.
Old 09-28-2016, 12:46 PM   #10
This page from the Champion website says different.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting - Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - 6 speed - Tow Package
boondocking is offline   Reply With Quote
inverter
