Old 06-06-2013, 03:11 PM   #21
Originally Posted by KyDan View Post
T 10 base white LEDs at a buck each including shipping.
10X T10 W5W 20 SMD LED 1206 Car Side Wedge Light Bulb 194 927 161 168 White-in Light Source from Automobiles & Motorcycles on Aliexpress.com
NOTE: LEDs are polarity sensitive. If you plug in an LED and it does not
light, rotate it 180 deg and try again!
Do those LED get hot? We too are looking to change out our bulbs to LED and are concerned about the fixtures that are in the bunk are and if they get hot like the halogens we are concerned about our son leaving a toy or stuffed animal against the fixture.
Buck1032 is offline   Reply With Quote
Old 06-06-2013, 03:12 PM   #22
KyDan's Avatar
Originally Posted by BarryD0706 View Post
I recommend against buying 12v LEDs. When you're on shore power, your system has 13.2+ volts. You should buy wide voltage range LEDs (like 10-30v that are easily found on superbrightleds.com).
These bulbs are sold for automotive use.
Your vehicle voltage is typically 13.5 or more when the engine is running.
For a measly buck each I'll risk it!!
Peace!
Dan & Rita D
Old 06-06-2013, 06:26 PM   #23
KyDan's Avatar
Most LEDs do not get hot.
Old 06-06-2013, 07:08 PM   #24
10x
Thanks for the info
2014 XLR 27 HFS
2010 F250 4x4 Crewcab Turbo Diesel
10x is offline   Reply With Quote
Old 06-07-2013, 07:02 AM   #25
KyDan's Avatar
I also ordered a pair of red led 1157 replacement dual intensity "bulbs".
Here is a link-- 2pcs 1157 BAY15D 18 SMD Red CANBUS OBC No Error Signal P21/5W Car 18 LED Light Bulb 12V-in Light Source from Automobiles & Motorcycles on Aliexpress.com
These will cost me $6 for the pair. Note- the "no error" means they have
a resistor built in. These LEDs use so much less power than traditional
tail light bulbs that some vehicles will show a false burned out message
on the dashboard. The resistor is supposed to prevent that false error.
In my case, I'm going to try them in my trailer tail lights. I've no idea
if they will appear any brighter than the normal bulbs back there but I'm
going to give them a shot.
OTOH, I might try one in my motorcycle tail light too. IF they are brighter
I'll use them, if not.... it was a $6 experiment and I learned something!
I've looked at LED replacement tail light assemblies for my trailer but most
are made for flush mount and that means you have to cut a large
hole in the trailer skin to install them. I'm not going to do that yet!
They (new tail light assemblies) are a lot brighter than my current tail lights tho..... IF you are interested in the assemblies, WallyWorld has them in the
automotive isle. They come packaged with a tiny disposable battery in the package. You can press the "test" button and actually see them lit up right
in the store. They are BRIGHT! If they had a surface mount version, I'd
have grabbed them the other day when I was looking!
Peace!
Dan & Rita D
Old 06-07-2013, 05:49 PM   #26
10x
Let me know how well you like them on your bike. I would like to install some on my Roadking.
2014 XLR 27 HFS
Old 06-11-2013, 11:02 PM   #27
Got mine in today. Looks great works perfect.
EHalpern is offline   Reply With Quote
