Old 06-08-2014, 03:27 PM   #11
RPAspey's Avatar
What was the voltage on the batteries? If it's too low, the clicking might be the charger going into safety shut down. Once it cools, it starts charging again. Get a HD battery charger as that looks more like a battery tender.
2000 Cherokee, 400w solar, 6v batteries, flipped axles, LEDs, etc. 2007 Tundra DC-LB, modded as well. C-co, 8/158th AVN Maint.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 06-08-2014, 11:12 PM   #12
camaraderie's Avatar
You need to hit those with a big charge...take it to the local auto store or your local service shop and get them to put them on a big boy overnight... You may have murdered them but since they are pretty new...you've got a chance to save them even with some damage.
One at a time on 6V is best. Two...bridged with a +/- cable is OK too.
If they aren't SEALED batteries...get a turkey baster hydrometer and take a reading on EACH CELL after you're done charging to make sure there are no dead ones that will ruin both batteries.
Good luck will be needed!
camaraderie is offline   Reply With Quote
Old 06-09-2014, 12:26 AM   #13
Batts-toy's Avatar
Give it some time, some chargers are designed to cycle on and off to attempt the recovery of totally dead batteries. After several hours if the charger is like mine it will stay on and slowly keep increasing the voltage.
Dale & Terri, Lulu & Tiki (our Chihuahua's), New rescue puppy Prince - Pom/Pug mix.
2013 Tundra, Double Cab, 5.7, TRD Off-Road, 4X4, Full Tow Package
2013 Wildwood T26TBSS - Sold
2000 Gulf Stream Sun Voyager M-8357 MH, Ford Trident V10 Gasser, 35 foot.
Batts-toy is offline   Reply With Quote
Old 06-09-2014, 01:24 PM   #14
I let it go all night. No luck. Next weekend I am just going to pull them and take them to test and charge them with a good charger.
Thanks for all the help. I will report back the verdict.
Looking for a new rig!!!
2013 Georgetown 329DS - SOLD
2017 Jeep GC Trailhawk TOAD
Klamaths Premium "Porter" JH RIP
Raney's Blazin' "Baxter"
All white Siberian Husky "Turbo"
goin2drt is offline   Reply With Quote
Old 06-15-2014, 07:32 PM   #15
First Happy Fathers Day.
Second I took the batteries in to the shop. They charged them and then put them on their machine. They said they were at 5.43 volts and the machine said to charge them, meaning they were not ok. The shop did not test the cells with a hydrometer. Fully charged shouldn't the batteries read over 6 volts.
I want to be extra safe as the last thing I want is to get stranded with not so good batteries.
Do you all say they need to be replaced?
Old 06-15-2014, 08:39 PM   #16
bubbles's Avatar
Originally Posted by goin2drt View Post
Update. Not sure what is going on now. The box in the picture keeps clicking about every minute or so. It clicks and the charger is then charging. Minute later it clicks and the charger is not charging.
Kind of weird.Attachment 54653
To me that looks more like the battery (power) control center, can't read the printing. If it is the sound you hear could be the relay switching from charging coach batteries to charging chassis battery. Maybe not.
Old 06-15-2014, 08:41 PM   #17
Fully charged 6VDC battery (lead acid - wet) should read 6.6VDC.
cadman99 is offline   Reply With Quote
Old 06-15-2014, 08:52 PM   #18
Correction 6.3...anything greater is surface charge.
Old 06-15-2014, 09:00 PM   #19
richard rv's Avatar
batteries
Good evening g2d..
I have worked with batteries most of my adult life and have seen a lot of changes in there design. A good battery will have a cell reading or 2.00volt per cell for a reading of 6.00 volt. A low battery will have a reading of 1.75 per cell (1.753cells=5.25). Your batteries are still good. I assume these are the house batteries lf so they are deep cycle batteries.this means that they were made to be discharged.this being said it means that it will take longer to charge up. The built in charger on your coach will charge them when you are plugged into a power supply or running the gen set. If your coach is like mine, look where your monitor for battery, water, waste tank is located and you should see a switch at the battery screen . it should say "use save".by pressing save you can shut down anything that is 12 volt and not repeat this again. Hope this helps
Richard & midget
Lexington sc
Jack our camping dog
richard rv is offline   Reply With Quote
Old 06-15-2014, 09:00 PM   #20
So if a full charge is 1 volt less am I asking for trouble to use these batteries?
charging, battery
