Old 04-05-2014, 02:09 PM   #1
Toad Haul's Avatar
Charging a Trolling Motor?
I've read thru numerous posts here about people wanting to add second batteries and found perfect solutions. However, is there any reason I couldn't do the same kind of setup to recharge my marine, deep cell battery for my trolling motor?
Simply extending the leads to recharge the battery overnight for the next day's fishing? The battery is stored in a Minn Kota charging station and I'm thinking I could just alligator clip up a connection?...would that work?
Darren, Donna & The Wieners
Toad Haul is offline   Reply With Quote
Old 04-05-2014, 10:05 PM   #2
kz08h5's Avatar
If you are talking about the Minn Kota Power Center all you should have to do is hook the charger up to the positive and negative posts on the front where the trolling motor leads are.
kz08h5
2008 Chevy Silverado 2500 Duramax Crewcab
Jeep Commander - sold
Flagstaff V-Lite WRB26
kz08h5 is offline   Reply With Quote
Old 04-05-2014, 10:19 PM   #3
Oklahoma Proud
MillerTime's Avatar
I think camper and boat batteries are the same. Seen some listed as Rv/ marine. They are a deep cycle battery so it will recover after being depleted further than a car battery. So if it works on a camper, it should work fine on a boat setup.
MillerTime- Future Sabre Handler!!
Old 04-06-2014, 10:05 AM   #4
Maybe - The problem is that typical battery chargers see the "full" battery. If you place a full battery and a discharged battery in parallel to a charger the discharged battery will either not be charged or get a minimal charge. You would need to disconnect the main battery and just connect to the battery to be charged.
cadman99 is offline   Reply With Quote
charging
