Old 10-06-2015, 10:34 PM   #1
Charging batteries, when rv parked for the season
I have a three stage converter on my motorhome, just wondering if anybody leaves they're shore power plugged during the of season, just to maintain the batteries
capitan is offline   Reply With Quote
Old 10-06-2015, 11:12 PM   #2
Left Coast
I do, and use an oil filled heater also.
Old 10-07-2015, 04:22 PM   #3
Not me, for me in this part of Canada it gets down to -20-30C, battery comes out and sits on two blocks of wood in my laundry room hooked to my charger.
Kevin
tenttotrailer is offline   Reply With Quote
Old 10-07-2015, 06:31 PM   #4
waiter21's Avatar
My Mirada has been plugged in since I bought it a year ago. One of the first things I did was to retrofit the single stage converter with a 4 stage.
Upgrading converter to 4 stage | 2001 Coachmen Mirada 300QB
I checked the water in the batteries last weekend, Level is OK for both coach and chassis. I'm happy with the converter....
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 10-08-2015, 01:14 PM   #5
I have for many years. Even on my old Class C. I just keep an eye on the water levels and fill when necessary. No problems so far for the last 10 or so years of doing this. I live in South East Michigan.
hatchet
HATCHET19 is offline   Reply With Quote
Old 10-08-2015, 01:54 PM   #6
camaraderie's Avatar
If you fully charge your battery...it will not freeze until -90 degrees. No need to store inside. Good to -16 degrees even if it is 60% charged. I fully charged battery will lose about 5% of charge / month in cold weather.
________
Cam
2015 Georgetown 280DS
camaraderie is offline   Reply With Quote
Old 10-08-2015, 02:55 PM   #7
Like Hatchet19 said, I keep mine plugged in all the time, just watch the water level. I've had a battery minder for about 10 years, replaces the normal battery plugs with an attachment that is attached to a rubber bulb that you use to fill the water from a bottle of distilled water. This way you don't have to keep taking the plugs out to check and fill the water. Just pump the bulb until you can pump any more.
tomrob1161 is offline   Reply With Quote
Old 10-08-2015, 03:12 PM   #8
Tom48's Avatar
I think our converter is basically a two-stage converter.
Original equipment by IOTA. Well for $20 on EBay I got their external plug. In that turns it in to a 4 phase charge controller. Jeez I bet that could have been in the unit originally for about $3 more. No needed often because of my solar but, hey now it is top flight. So I did it.
Tom48 is offline   Reply With Quote
Old 10-09-2015, 08:37 AM   #9
peaceparson
Do you fill with distilled water, tap water, or acid when the level becomes low? My battery is far too heavy to move indoors, plus I don't want a charging battery inside the house. I will be leaving it on the trailer and pluggfing into the garage outlet through the cold weather.
peaceparson is offline   Reply With Quote
Old 10-09-2015, 08:42 AM   #10
Always distilled water.
hatchet
Old 10-09-2015, 08:43 AM   #11
Keep in mind there are parasitic draws on most rvs that will discharge the batteries in a month or less.
Old 10-09-2015, 09:18 AM   #12
acadianbob's Avatar
The 3 stage units are really just trickle chargers on the lowest setting. They can still over-cook your batteries over time. IMO, the best option is to disconnect the batteries from the RV and then hook a Battery Minder to the batteries. A Battery Minder is a smart charger and has anti-sulfation techology. My tractor, RV, motorcycle batteries last 7 to 10 years using these devices and they are always topped off and ready to go.
2021 F350 Lariat 7.3 4X4 w 4.30s, 2018 Wildcat 29RLX
Red Green coffee mugs
Old 10-09-2015, 09:55 AM   #13
Left Coast
Depends on hard or soft water avalilibity.
Old 10-09-2015, 04:44 PM   #14
I Always leave mine plugged in...
sunnyinfla is offline   Reply With Quote
Old 10-09-2015, 05:01 PM   #15
amblt's Avatar
I have no faith in the inverter/charger units installed by the manufacturers. I've had several expensive batteries ruined while installed in trailers during the summer, let alone the off season. I recommend removal and regular checking and charging if required.
amblt is offline   Reply With Quote
Old 10-09-2015, 06:45 PM   #16
All season long
I have a 5th wheel and upgraded my converter to a 4 stage unit and with this i do not even have a issue with the water, so as long as you do have at least a 3 stage unit you should be good, just keep an eye on your water for the first season to know how your unit works for boiling the water in the battery
B.Smith
2010 Cedar Creek Silverback 35ts
2001 GMC 2500HD w/ Allison & 8.1
silverback 35ts is offline   Reply With Quote
charging, battery
