Old 05-14-2013, 07:28 PM   #11
Denver, CO
garbonz's Avatar
I have 2 80 watt ARCO (now BP) panels on roof racks on the truck roof and just keep the truck in the Sun. So the maximum I can expect to gain on a sunny day is about 50 amps. Typically that is enough for the incidental 12 volt stuff like lights, etc. I too use a generator for the 110 volt stuff. An inverter.just uses to much battery capacity unless you have a huge bank. I have 2 deka 6 volt batts with 210 AH capacity and that works fine
2017 Fuse 23T
solar
