Old 01-12-2016, 03:42 PM   #11
Too Tall's Avatar
thanks, I got the CPAP to run also.
Rockwood 2104S, 2014 Ram 2500 Diesel.
USMC 68 -70
Too Tall is offline   Reply With Quote
Old 01-12-2016, 03:56 PM   #12
bikendan's Avatar
Any 2000w inverter generator should be adequate for what you want.
We only have to run our Honda 2000 for 2-3 hours every 3 or 4 days.
But that's without using the furnace. If you use the furnace, expect to use the generator more.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 01-12-2016, 04:23 PM   #13
prof_fate's Avatar
i got a powerstroke genset from costco this week - $449, 1700w running plus it has a 12v charge port and cable for doing batteries. Claims to run 12 hours on 1 gal of gas at moderate load. 46 lbs.
due to the ugly weather here I've not tried it out yet...14f yesterday and 3" of snow and still snowing now...need to get gas for it as all i've got on hand is 2 stroke fuel for my snowblower.
Plan to bookdock this year. Last summer was at a CG and the power kept going out...of course it was at the exact time i needed to make coffee and use the microwave! LOL.
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
Old 01-12-2016, 04:33 PM   #14
Originally Posted by Too Tall View Post
thanks for the reply, my RAM diesel has a pretty significant alternator but I'm not going to run more than 15 minutes or so and I don't think that's enough. I should have added, I'm talking about a travel trailer, not motorhome.
Yes, 8 amps charging two batteries would be all day, I guess. I'm thinking of connecting it to the power cord on the camper and letting the camper's inverter charge it. That may be slower however.
How do most people handle charging.
If you buy a 2000watt inverter generator (Champion is a good brand) you can charge your batterys through the converter (shore cord) at whatever amperage your converter puts out. Plus you will be able to run your microwave if needed.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 01-12-2016, 04:38 PM   #15
Flybob's Avatar
If you are using a small generator to charge your batteries, do not use the 12V charge port. Connect your shore power cord to the generator AC socket and allow the converter to charge your batteries. It will charge faster and safer.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-12-2016, 05:19 PM   #16
Pickin' & Campin'
Flybob gives good advice here. The 12v chargecport/cord provides very limited charging amps. Plug in the shore cord or I think the OP mentioned a stand alone charger... plug that in and connect to the batteries for even faster charging. (depending on charger's options)
Days Camped: '15=22 '16=46 '17=30 '18=4
Old 01-12-2016, 05:38 PM   #17
Bluepill's Avatar
Too tall: To give a meaningful answer about charging time, we need to know what group size batteries (24, 27, 31, 105, etc.) or the amp hour rating of each battery.
Then we need to know how many amps your converter/charger puts out.
FYI, a 1000 watt genny does only produce about 8 amps at 120 volts, but that will power a charger of up to 50 amps at 12 volts.
watts = amps x volts, so 120 volts x 8 amps = 960 watts
Charger at charging voltage of 14.5 volts x 50 amps = 725 watts. Adjust for charger efficiency of 80% puts you at a bit above 900 watts required from genny.
That assumes that genny 1000 watt rating is continuous, not surge or time limited.
As already mentioned, a 2000 watt genny is probably best, since you don't want to run near 100% power for a long time, no matter what the rating. It also gives you the power for a single large appliance like a hair dryer or larger microwave.
2008 Itasca Meridian 37H
Bluepill is online now   Reply With Quote
Old 01-12-2016, 05:57 PM   #18
Too Tall's Avatar
OK, that's good advise. I'm going to look for a 2000, not much difference in price for a 1000 and I can run more stuff.
USMC 68 -70
Old 01-12-2016, 06:00 PM   #19
Too Tall's Avatar
Thanks, yea the 2000 is definitely the way to go. I was thinking Honda but others mentioned Champion.
USMC 68 -70
Old 01-12-2016, 06:06 PM   #20
Flybob's Avatar
Many people buy the 1000 only to wish they got the 2000. If you have a 2000 and you upgrade TT at a later date, you can add a companion 2000 and run the AC. Long thread here last week on best generator prices. Here is link.
Best price on Honda generators?
TST Tire Monitors
2 100W solar panels
battery, camping, charging, dry camping
