Old 06-03-2015, 12:39 PM   #21
Originally Posted by ScottBrownstein View Post
If you shut off all of the other breakers and the problem persists, it has to be the converter or the genny. Clamp on ammeter would help decide which is the problem. Converter isn't a monstrous load.
My batteries charge just fine with I'm on shore power with my normal 30 amp connection at the campsite. Hence I do not think it is the converter. My generator will power my 5th wheel under normal conditions (that is without the batteries connected). I will call the generator company to see if they have any ideas.
Carlg is offline   Reply With Quote
Old 06-03-2015, 12:41 PM   #22
TURBS's Avatar
How new or "old" are the batteries?
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
Old 06-03-2015, 12:47 PM   #23
TURBS
2011 32bhok Sabre
The batteries are about 4 years old but are holding charge very good. They drive all the dc circuits nicely. I have charged them recently (within the past two weeks)
Old 06-03-2015, 03:23 PM   #24
Try plugging in some appliance that uses 1600-1800 watts and see if this overloads the genny. If it does then I would suspect your genny is at fault.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is offline   Reply With Quote
Old 06-04-2015, 12:35 PM   #25
Most of this discussion has been about possible issues with the load on the generator. I ran into the exact same problem with a Yahama 2000W generator with only a 300W load on it. It ran for a while then quit. It turns out that the generator has three separate controls that must be turned on for the genny to run. I had only turned on two of them and forgot about the cap valve that allows air to replace used fuel. This turned out to be a bigger problem when the gas tank had just been filled and there wsa almost no air in the tank. Gas doesn't flow from the tank when there's a vacuum keeping it there.
Phil
pmsherman is offline   Reply With Quote
Old 06-05-2015, 10:53 AM   #26
Originally Posted by Carlg View Post
I have an external generator 2000 watts. I have tried to charge my batteries using the 30 amp ac connection. The generator runs for a while and then overloads. I have two 6 volt batteries in series and have no problem with normal ac connections or truck connections to charge my batteries on my 5th wheel. Any suggestions?
It sounds like everyone agrees, you have other things running causing too high of a draw on the generator. Unless you are running your ac or furnace your biggest draw would be the water heater. It is probably set to run on your 110 ac. Either shut it off or switch it over to run on your propane.
I just got a Honda 3000 watt generator. I questioned if I needed a 3000 till I started addng up everything. I want to be able to use my ac or furnace when needed and a 2000 watt won't do it.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 06-05-2015, 02:36 PM   #27
Well I have returned the generator after I found that it only provided about 1 amp before it overloaded. Now I'm looking for another portable 2000 watt generator. I have some good reports about a Westinghouse WH2000ixlt. Does anyone have some experiences with a good 2000 watt inverter generator.
carlg
Old 06-05-2015, 03:00 PM   #28
TURBS's Avatar
carlg
Just others know what was the generator?
TURBS
2011 32bhok Sabre
Old 06-05-2015, 03:30 PM   #29
HONDAMAN174's Avatar
If you are looking for economically challenged, I have heard good things about the champion invertor genny's:
Champion Power Equipment 73536i 2,000 Watt 4-Stroke Gas Powered Portable Inverter Generator (CARB Compliant) https://www.amazon.com/dp/B0041K09D8..._jAGCvb14ZAPKS
Champion Power Equipment No.75531i Inverter Generator, 3100-watt https://www.amazon.com/dp/B00BBDCE1S..._SBGCvb16F2YDR
Just glad to get away
Old 06-05-2015, 06:38 PM   #30
I liked my Honda 2000
It looks like you are now in the market for a different generator.
I never had a problem with my Honda 2000. I could even run the roof a/c on my TT if I not only turned off all loads, I also turned off the converter. If I left the converter on then the a/c would start once but when it cycled off/on it would trip the Honda breaker.
Many people do not like the price of a Honda or Yamaha.
$950/8 years = $120/year. I still have it. If it lasts 20 years then that will be $50/year.
The Honda is not the cheapest around. I don't think the Yamaha is all that cheap either.
I got the Honda instead of the Yamaha because I can carry it with one hand while the Yamaha requires two hands. I can handle weight on my side but if that much weight is in front of me then I might throw out my back.
I know, I know, too much information. I apologize.
Wayne in Coarsegold near Yosemite
2013 Forest River Solera 24R
2014 Jeep Wrangler Rubicon
ATV trailer for the following toys
2008 Yamaha WR250R,2009 Honda CRF150F
2008 Polaris Scrambler 500
PopBeavers is offline   Reply With Quote
charging, generator
