Old 06-05-2015, 06:42 PM   #31
I own a Champion 2000 watt inverter genny and I am quite pleased with it, it is no louder than a Honda and starts on first pull every time.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
Boon Docking 99% of the time.
2009 F150 - 5.4 Litre - Tow Package
boondocking is online now   Reply With Quote
Old 06-05-2015, 09:59 PM   #32
Just out of curiosity how do you get the gas out of the tank when you quit using the unit. I'm told that you need to remove the fuel if you do not use for a while (more than a week)?
Carlg is offline   Reply With Quote
Old 06-05-2015, 10:18 PM   #33
bikendan's Avatar
This is misinformation.
For example, the Honda 2000 has a locking vent cap. So you don't have to remove the fuel.
I leave mine in for the whole camping season.
Dan-Retired Firefighter/EMT
Equalizer WDH and Prodigy BC
Old 06-05-2015, 11:08 PM   #34
Never seen gas go bad that quick. If you are really concernrd just add a little bit of stabil (sp) to keep it fresh.
Jim
07 Dodge 1500 crew cab with 20" wheels, 08 Forest River Rockwood Signature Ultra-lite 8280SS
"The reasonable man adapts himself to the world; the unreasonable one persists in trying to adapt the world to himself. Therefore, all progress depends on the unreasonable man."
George Bernard Shaw
oldtool2 is offline   Reply With Quote
Old 06-05-2015, 11:21 PM   #35
I don't use Stabil and I leave gas in my Honda 2000. I have had it since Spring 2009. Still starts in 2 pulls.
Maybe I am just lucky.
Wayne in Coarsegold near Yosemite
2013 Forest River Solera 24R
2014 Jeep Wrangler Rubicon
ATV trailer for the following toys
2008 Yamaha WR250R,2009 Honda CRF150F
2008 Polaris Scrambler 500
PopBeavers is offline   Reply With Quote
Old 06-06-2015, 12:14 AM   #36
HONDAMAN174's Avatar
I've added stabil and had issues. Others have had good luck so maybe I'm doing something wrong.
Just glad to get away
Old 06-06-2015, 09:08 PM   #37
I use the Yamaha 2k. I just shut the gas off and the genny dies on its own when the card runs dry. I leave the gas in the tank till the next time. The Yamaha wasn't cheap but I'd do it again.
2018 XLR Nitro 36T15
2015 GMC 3500 6.6/Allison
Nights Camped (2017- 16) (2016-13) (2015-13)
SuicideSaints is offline   Reply With Quote
Old 06-07-2015, 07:24 PM   #38
wbdavey's Avatar
I had a Honda 2,000 watt inverter gen. As I recall, it has a separate plug and cord specifically to charge 12 volt batteries. Eliminates all the converter/charger/other loads being fed while you only want to charge the battery.
2015 Rockwood Ultra Lite 2604 WS. Rear LR, large street side slide with small wardrobe slide in BR.
2014 Ram 1500 Eco Diesel Laramie Quad Cab.
wbdavey is offline   Reply With Quote
Old 06-07-2015, 08:02 PM   #39
But it will take more time that way. And it will not automatically switch between bulk mode, charge mode and trickle mode. If you do that for too long (days or weeks) it will damage the batteries.
There is a reason that the converter has 3 stages. I take advantage of that all of the time. I can not think of any occasion when I wanted to bypass the converter.
Old 06-07-2015, 09:17 PM   #40
As PopBeavers says, it will take more time. The Honda 2000 puts out only 8 amps @ 12 vdc, which is only a fraction of what the converter puts out when powered by a generator.
2007 Surveyor SV230
charging, generator
