Old 02-22-2016, 04:08 PM   #1
Charging with generator question
My father-in-law and I went dry-camping this past week in separate trailers, his an '09 Flagstaff 5er and mine a '16 Flagstaff TT. He has a Honda eu2000 generator. I found need to recharge after 2-3 days when my batteries were almost completely down. Some questions/concerns came up as a result of our experiences charging both rigs:
1. Why would my TT put such a heavy load on the generator when first plugged in? My fridge was on propane only (I made this change away from letting it pick automatically), and maybe only 1 LED light was on and 2 devices were charging. Heater was off. For about 20-30 minutes (maybe longer?), the generator was kicked up as if under heavy load and then it would finally kick back down to lower RPM. But even after 2-3 hours on the generator I barely got back to halfway charged. Was it just not enough time on the generator for a full charge? Would a bigger generator give me faster re-charge times?
2. My father-in-law plugged into his trailer and it kicked up RPM's for maybe 5-10 minutes and then it would kick back down to the lower RPM range for the rest of his charge. He also noted that a longer time on the generator didn't give him full charge.
3. With almost completely dead batteries on the way home and plugged into the truck I only got about 3/4 charged on the ~ 2.5 hour trip home. Is this just not enough time to fully charge given the time and vehicle (2015 F-150 EcoBoost)?
Hopefully this is enough info to get some ideas here. My father-in-law believes that the initial draw issues may be in some part due to either a short somewhere or maybe something wrong in the charging system itself (rectifier?).
2016 Flagstaff 27 BEWS
2015 Ford F-150 XLT EcoBoost
jlindo is offline   Reply With Quote
Old 02-22-2016, 04:27 PM   #2
Bluepill's Avatar
1. You should not discharge you batteries beyond 50% of their capacity, it shortens their life a lot. So does charging too quickly, as it can overheat the batteries.
2. You might try switching off 120 volt circuit breakers just after powering up the generator to see if any particular circuit besides the converter/charger is using much electricity.
3. We can give you better and more specific advice if you will list exactly what batteries you have (Amp. Hours, or at least Group number). Model number and brand of your converter/charger would also be helpful.
4. It is doubtful that a larger genny will decrease charging times. Those times are controlled by the size (capacity) of your converter/charger. A larger converter *may* shorten charging times. There are many factors that effect charging time.
FYI, a 65 amp converter/charger draws a maximum of about 1000 - 1200 watts from the genny.
2008 Itasca Meridian 37H
Old 02-22-2016, 04:41 PM   #3
SKnight's Avatar
Well, it depends on what you mean by almost completely dead, you shouldn't let batteries get below 12.1V which is 50% discharged. The lower the batteries are the charge time increases exponentially.
I've got a 65 amp converter, and I'd charge everyday which was usually at 12.3V or 70%. The generator would only need about two hours to charge up. But, that would only get me to 95ish% as I didn't want to let it take the time to finish up as that last 5-10% takes a while.
If you're really dead, then initially the converter was working really hard to charge the batteries, drawing a lot of power, which likely explains the high RPM on the generator.
Your father in law could have been discharged less, have a different converter that has a different rate, etc.
Finally, your truck has a probably 12ga wire that's about 18 feet long, it can only flow so much electricity, it's really only there to maintain the batteries while towing, not to charge them from dead.
Old 02-22-2016, 05:04 PM   #4
Thanks for that! I would have never expected/anticipated that. Based on this then, the fact that the CO2/Propane leak detector malfunction due to low battery means that I went too low. Correct?
I'm assuming here I can test one or both of the batteries with a meter for the volt level/value?
Old 02-22-2016, 06:19 PM   #5
Sorry, but it all depends. Actually it seems that your converter stayed in high output boost mode longer since it loaded the genny for a longer time. Now, assuming that you both have the same number of batteries and the same converter, his simply dropped out of boost sooner. However, it takes a long time to get back to 75% or 100% SOC. Batteries can only take current for so long without getting too hot and, as they charge they begin to fight back as the voltage rises. Converters will drop out of boost if they sense a significant back voltage in an attempt to keep the batteries cool. As far as the "long trip home" is concerned, 2-1/2 hours isn't much when the feed line from the TV is long and of a relatively light gauge.
That being said, other posters are absolutely right, going below 50% state of charge is not recommended for lead acid batteries. If you have a real battery monitor (Trimetric or other) they will measure how much current has been put back in and for how long.Since they measured how much came out, it is a relatively easy process for them to give you accurate SOC. Voltage monitors like the LED ones that come with RVs are really of little use in determining SOC. I worried about my 4 12 volt deep cycles a lot until I put in a TriMetric. Now I know not only how much is left in the bank, but also how much is going back in when the engine or generator is running and when connected to shore power. The LEDS really don't help here. Frankly I don't understand why RV manufacturers don't put them in as standard equipment. The total cost is less than $200 and they are well worth it!
2015 335DS
ScottBrownstein is online now   Reply With Quote
Old 02-22-2016, 09:33 PM   #6
SKnight's Avatar
In the field I use a voltmeter to monitor my voltage at my fuse box, one day I'll install a permanent voltage display. But to truly measure battery health pick up a hydrometer at a parts store. That will tell you more that just the voltage, which is important, but doesn't tell the whole story.
Old 02-23-2016, 12:20 PM   #7
Another thought regarding high amp's while charging is electric. hot water heater switched on. Do you have one and was it on?
Burk
Burk is offline   Reply With Quote
Old 02-23-2016, 03:18 PM   #8
camaraderie's Avatar
1. You cannot apply more than 25% of your batteries amp hour capacity in charging current. BIGGER converters won't charge you up fully 1 second faster than a properly sized converter. If you have a couple of group24 batteries that is 150 amp hours so an charger more than 35-40 amps is overkill. Pair of Group 27's are 200 amp hours ...so they can take 50 amps...etc.
2. VOLTAGE is NOT how you determine if a battery is full when it is connected in a coach. That is only good for a static bench test after waiting 24 hours DISCONNECTED after charging! Not real practical in use!
You either need to spend for a REAL battery monitor ($150) or get a turkey baster hydrometer at autozone and test the specific gravity of the cells. SKnight has it right.
3. If you are discharging your batteries to 12.2V then it will take roughly 6 hours to FULLY charge them with a PROPER sized converter and wiring. You can get away with bringing them up to 90% or so with a 2 hour charge for a bit of camping but suggest a full charge at least once a week in use to avoid loss of capacity.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 02-23-2016, 03:20 PM   #9
Battery Voltage level
We are not full timers but well over 100 nights last year. I wanting to put a voltage meter so I can consistently have a view of my battery condition. I have a 28RKS Wildcat. Does anyone have a recommendation of the best place to wire into the system and mount it. My monitoring panel is half way between the batteries at Gege front and my electrical panel, inverter etc at the rear. I think I'd like to mount it by the existing monitor panel but not sure if there is an accurate tie in point there. I'll wait your comments.
Thank you
Filterman
Floyd & Carolyn
2012 F150 S/crew 4X4 6.2L 6Spd Tow Max Firestone airbags. 2011 28RKS Wildcat. Yamaha 3000iseb Gen.
2013 22 nights.2014 57 nights.2015 116 nights
2016. 96 nights 2017 72 nights.
Filterman is offline   Reply With Quote
Old 02-23-2016, 03:38 PM   #10
Filterman...if you are boondocking rather than plugging in for a lot of that..you should have a battery MONITOR not a VM. You can mount the Victron controller/readout wherever you can reach with the STANDARD PHONE WIRE that connects to the shunt.
Victron Energy BMV700 Precision Battery Monitor Free Shipping | eBay
Trimetric makes a similar instrument that a lot of folks use but it is more expensive and does no more.
________
Cam
charging, generator
