Old 06-27-2016, 09:20 PM   #1
Chassis accessories will not operate.
The power seats, rear view camera, leveling system and some dash board lights.
But when I press the emergency battery start button (where the two banks of battery are used). The accessories comes on while I hold the the button.
I have tested the chassis batteries indiviallg. Both at 12.8v with no load.
Check the 250amp 32v buss fuses. (Both seem ok. Top fuse has a positive and negative and 14v between them). Bottom fuse has two positives. (Not sure if this is correct)
Checked the battery disconnect toggle switch and it's ok.
Checked the two 5amp fuses on the solenoid in the back compartment and they're both ok.
Any help or suggestions is greatly appreciated.
Thank you.
Last time an RV mechanic said he just changed a fuse and everything was ok. Haven't been able to reach him to find which one.
Name:	ImageUploadedByForest River Forums1467080377.076168.jpg
Name:	ImageUploadedByForest River Forums1467080250.683622.jpg
ID:	112430Click image for larger version
Name:	ImageUploadedByForest River Forums1467080264.731860.jpg
ID:	112431Click image for larger version
Name:	ImageUploadedByForest River Forums1467080278.585437.jpg
Henry3e is offline   Reply With Quote
Old 06-27-2016, 09:47 PM   #2
2005 sportscoach
accessories
