Old 07-12-2014, 02:14 PM   #1
Circuit breaker problem 2011 Solera
I have a 2011 Solera. When I run the microwave while running the air conditioner it trips the circuit breaker. Does this mean I need to replace the circuit breaker?
kwelliff is offline   Reply With Quote
Old 07-12-2014, 02:24 PM   #2
New to Forest River
Roving Ron's Avatar
This is not really a problem. Your unit is not designed to draw enough current to supply both microwave and AC. You will need to turn off the AC while using the microwave. This also applies to appliances like toasters and electric griddles.
Ron
Grey Nomads, Ron and Sue
Grey Nomads:l Ron & Sue
Roving Ron is offline   Reply With Quote
Old 07-12-2014, 02:25 PM   #3
Witch Doctor's Avatar
What breaker are you tripping?
Coachmen M/H
Concord
2018 / 300 DSC
Old 07-12-2014, 02:26 PM   #4
OK I figured it out
Just read elsewhere that someone had problem tripping circuit while running water heater, AC, and Microwave. Basically exceeding the 30 amps of the main breaker. I was utilizing the electric water heater switch to save propane.
Old 07-12-2014, 02:40 PM   #5
fonzie's Avatar
Here is a list of normal current draw for RV appliances....it does not take too much to exceed 30 amps....
normal appliance amp draws
Fonzie
breaker, solera
