Old 07-17-2016, 10:06 AM   #1
Class C Battery question
We have a new Sunseeker Class C 2430 GTS. Getting ready for a 3 week trip. Previously owned two Class B's and a Class C so we are not totally newbies. I have searched my manual and this forum but can't find the answer to this basic question:
Will our house batteries be charged by the chassis (Ford 450) as we drive? And will the generator charge them when we are dry camping?
We have a battery charger that we could bring along but not sure if we need it.
We just charged up the house batteries and they are full (now).
Thank you in advance. I have learned many things from this forum!
Gizmosmom is offline   Reply With Quote
Old 07-17-2016, 10:25 AM   #2
2012 Solera
Assuming everything works as designed, yes and yes. House batteries should be charged while you drive and should be charged whenever you have 120 volts ( generator or shore power) to the unit.
JLeising
2012 Solera "S"
Calif SF Bay Area
Old 07-17-2016, 10:50 AM   #3
World Wide Wanderer
wahoonc's Avatar
That is the way it is supposed to work. I am a belt and suspenders guy so I bring a portable charger as well as my solar panels.
Just for the record, the generator charges the house batteries via the on board converter/charger the same way it does it via 120 volt power.
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
wahoonc is offline   Reply With Quote
Old 07-17-2016, 12:22 PM   #4
Thank You! This helped us immensely! Our last "new" RV was a 2000 Class B van. Seems like the newer technologies have us a bit confused!
Old 07-17-2016, 01:03 PM   #5
17Racer's Avatar
I believe the battery cut off switch by the door needs to be in the on position. As it would be while camping.
2014 Forester 2301 - Chevy
17Racer is offline   Reply With Quote
Old 07-17-2016, 06:44 PM   #6
World Wide Wanderer
wahoonc's Avatar
Maybe... On my current unit I am not sure, need to check. I know that the solar panels will charge the batteries even with the battery switch off. Not sure about the converter and engine.
Aaron
Aaron & Rhonda
Old 07-18-2016, 12:33 PM   #7
sgtlm17's Avatar
Yes if installed correctly solar panels should be directly wired to batteries from controller. So battery cut off switch does not affect solar charging.
2016 Forester GTS 2801QSF
sgtlm17 is online now   Reply With Quote
Old 07-18-2016, 12:50 PM   #8
camaraderie's Avatar
May I suggest you bring a simple voltmeter with you to test the charging sytem any time. Just touch the leads to the battery terminals when you think you should be charging and you should see at LEAST 13.2 volts... anything less and you're not charging.
________
Cam
2015 Georgetown 280DS
2014 Vespa LX150 2014 StellaAuto 125
camaraderie is offline   Reply With Quote
Old 07-18-2016, 06:58 PM   #9
X2 17Racer
battery switch by door must be in the on position to charge your batteries while driving. If the switch is in the off position then you will be charging your truck battery.
I find it easy to remember to turn the battery switch on and off as all the TVs and appliances light up otherwise they don't when the battery switch is in the off position.
_______________________
2013 Sunseeker 3170ds
Retired...but still have a boss.... and no HR to complain to!!
bobbrown is offline   Reply With Quote
battery, class c
