Old 06-23-2016, 08:45 PM   #1
JDcamper's Avatar
Clearance lights partially out
When hooking up my Sandpiper 5th wheel today to pull it next to my house for loading, I noticed that my front top clearance lights did not work. I then inspected around the camper and all the side marker, tail lights, and tag light work. On the rear the two left (drivers side) top clearance lights work but the right side do not. In order to rule out a TV fuse, while plugged into shore power, I jumped the running light to the positive terminal on the TV power cord and the clearance lights were still not working while the other running lights were. Any suggestions for repairing would be appreciated. I am heading out for an 8 day trip Saturday and while I have no current plans to drive after dark, one never knows what might happen.
2016 Sandpiper 380BH5
2012 Silverado 2500HD Duramax
JDcamper is offline   Reply With Quote
Old 06-23-2016, 08:47 PM   #2
SeaDog's Avatar
To me this sounds like you lost the ground.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 06-23-2016, 08:56 PM   #3
Left Coast
Bulbs burnt out? Pull a lense off and wiggle the bulb while power is on...
Retired....but work part time as a pain in the north end of a south bound donkey.......2010 Rockwood 8280 5er....99 Dodge 2500 turbo Cummins
bob caldwell is online now   Reply With Quote
Old 06-23-2016, 09:09 PM   #4
trbomax's Avatar
Yeah,those lights have the ground thru one of the attachment screws. On an aluminum sidded trailer,the steel screw corrodes where it touches the aluminum. Not sure how they do it on a Filar wall but you can bet its cheap and quick.
trbomax is offline   Reply With Quote
Old 06-24-2016, 08:08 AM   #5
JDcamper's Avatar
Thanks for the replies. Assuming it's a bad ground, where would I begin to look. I have a junction box mounted on the back of the king pin box. I opened the cover on that and all wires appear to be connected sufficiently and there is a ground post in the box. I checked it for tightness and all appeared to be in order. I also wiggled the wires to see if there was a possible short and find nothing. Where is the most likely place for the ground connection on the chassis. My underbelly is enclosed with the corrugated plastic panels which I assume would have to be removed to access the wiring. However, since it is the top lights that are not working, I am afraid the wiring is going through the ceiling. My unit is still under warranty until August, but given the norm for most dealer service centers, my camping season will be shot if I take it in now.
Old 06-24-2016, 08:30 AM   #6
RSchleder's Avatar
Sounds like, assuming the above is true on your unit, you need to remove the light sockets, one at a time, redo any ground connections (one of the socket mounting screws thru the aluminum siding that has a wire attached to it) and try the lights after each socket with a ground is reworked to see if the issue is fixed.
Days camping (2016)----181 days
Days camping (2017) --- 52 days
2016 Wildcat MAXX 28RKX (33' TT), 2007 13' Scamp
2015 Ram Laramie Hemi, w/air suspension
30 years RV'ing
12 different RV's
RSchleder is offline   Reply With Quote
Old 06-24-2016, 08:34 AM   #7
B and B's Avatar
A Digital Meter would work to test for voltage. I doubt all bulbs are bad on a 2016 RV but who knows.
Take off one of the lights. I bet a loop through connection is broken. Check all connections. You also have a non metal trailer so the lights each have a ground connection. There are butt splice crimps most likely, make sure they have not stripped a wire or crimped insulation instead.
B and B
2017 Heartland Bighorn 3575 Elite
2016 Ford F 350 Lariat Power Stroke Diesel Crew Cab FX4
"Oh Canada,True North Strong and Free!"
B and B is online now   Reply With Quote
Old 06-24-2016, 09:03 AM   #8
JDcamper's Avatar
Thanks for the help. Will try RSchleder's and B and B's steps when I get home from work this afternoon. Also, for what its worth, I did just finish washing the RV prior to hooking up to pull beside my house. I guess it is possible that water may have gotten in and shorted a wire?
Old 06-24-2016, 09:12 AM   #9
Left Coast
Maybe find an auto repair shop close by....if the lights have ever worked, wouldn't take much to fix
Sent from my XT1585 using Tapatalk
Old 06-24-2016, 09:25 AM   #10
Remove the lens, sand paper the bulb and socket. These lights are notorious for loosing bulb to holder connections.
light
