Old 05-18-2014, 04:52 PM   #1
Jmsx2's Avatar
Coach Battery Question
Hello Gang,
Hope this is the place for my question. We just park our 2015 Sunseeker 3050S on a storage lot of a campground. I just realized that I left the Coach Battery Switch on.
I can't get back up there till tomorrow afterwork to turn it off. We have nothing running so our question is how long will those batteries last if the switch is left on. It will be about 30 hours of being left on before I get there.
Also, if they go dead, will simply plugging into shore power enough to start charging them. Also, with dead coach batteries, can I still run everything on the coach plugged into Shore Power until they reach full charge?
Thanks everyone.
John & Janine
Pazzo (Maltese)
New Brighton, PA.
2018 Coachmen Chaparral 338 TSIK
2016 (Seasonal Site) Chariot Park Model
2015 Chevrolet Silverado 2500HD
Jmsx2 is offline   Reply With Quote
Old 05-18-2014, 04:59 PM   #2
They should be fine. If for some reason they go dead, plug the coach in and the charger will take care of it. Once you are plugged into shore power the converter takes over. In other words it will convert 110vac to 12vdc and the charger side of the converter will charge your batteries. Plugged into shore power or running on generator makes everything functional.
2014 Georgetown 351DS
-TruCenter -Front/Rear CHF -Hellwig Links -Tiger Trak -Ran McNally GPS -ScanGauge -Truck Systems TPMS -5 Star Tune
alparmer is offline   Reply With Quote
Old 05-18-2014, 05:00 PM   #3
Just for kicks, check the water level of the batteries.
Old 05-18-2014, 05:09 PM   #4
Jmsx2's Avatar
Sweet... That was my thinking, but I just wanted to be shore..
Thanks for responding so fast...
John & Janine
Pazzo (Maltese)
New Brighton, PA.
Old 05-18-2014, 05:11 PM   #5
Jmsx2's Avatar
Probably a good idea. Even though everything is only a 45 days old, I should keep an eye on them..
John & Janine
Pazzo (Maltese)
New Brighton, PA.
Old 05-19-2014, 06:54 AM   #6
RPAspey's Avatar
You should only check the battery fluid when FULLY charged. Otherwise you may over fill them.
2000 Cherokee 31BH, "flipped axles and raised",LEDs, solar, inverter, etc..aka "boondock ready". '07 Tundra 5.7L DC-LB, modded as well.
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 05-19-2014, 03:21 PM   #7
Jmsx2's Avatar
You are correct.. I'll do that this weekend.
Thanks everyone for all the help......
John & Janine
Pazzo (Maltese)
New Brighton, PA.
battery
