Old 02-22-2012, 07:49 AM   #1
Coach Battery Solenoid
I have a 2002 Forest River Reflection on the Freightliner chassis.
I am having problems with the coach battery solenoid.
Does anyone know where it is physically located on this unit?
Thanks in advance.
bamapirate10 is offline   Reply With Quote
Old 02-22-2012, 08:28 AM   #2
TURBS's Avatar
How do u know your having problems with it if you don't know where it is?
What problems are you having?
Old 02-22-2012, 09:26 AM   #3
What its doing
When i take it off shore power and put it on battery the lights stay on inside for a few seconds and then the solenoid releases. You can hear it release and you can hear it try to activate with the switch.
I can trace the click, but thought somebody might have had same problem and know where it is.
Old 02-22-2012, 09:37 AM   #4
TURBS's Avatar
Hmmm normally they would be very cl
ose to your distribution panel and or batterys.
It almost sounds like your transfer switch if equipped is bad imo
Not sure tho
Old 02-22-2012, 09:47 AM   #5
Already had the isolator off an tested with no problems.
Old 02-27-2012, 07:54 AM   #6
transfer switch
I took off the solenoids and tested and they are fine.
I went to the Transfer Switch and it clicks when the power goes off.
From what I read about Transfer Switch it controls the transfer from shore to generator. Does it also control transfer from shore to 12V?
battery
