Old 08-19-2013, 10:15 AM   #11
brockhals's Avatar
No idea how far or direction for that matter. I did rotate it as well but nothing. Think the TV was on Cable though...will have to check that one
Booster was on, but there's no cell service at this site (for AT&T anyway) so the app won't help me.
Brock
2007 Coachmen Capri - 300QBS
2012 Yukon Denali Tow rig
brockhals is offline   Reply With Quote
Old 08-19-2013, 10:32 AM   #12
If the signal is weak, you would have to rotate it pretty accurately so just random try's isn't going to work (quickly).
Since you know in advance where you're going to camp, use the app while you still have signal to help you determine the angle of rotation (off of true north) and then your phone compass to orient that relative to how your RV is parked.
Old 08-19-2013, 10:40 AM   #13
brockhals's Avatar
Ok thanks Barry. How will I know how the antenna is pointing? Is that the point on the crank? Point that in the direction?
Brock
Old 08-19-2013, 11:01 AM   #14
I believe the point on the crank is off by 90 degrees. It's easiest to just to look outside until you figure it out. The antenna's extended arms should be open to embrace the source of the signal (eg, not pointed at the source).
Old 08-19-2013, 11:07 AM   #15
mshell56118's Avatar
I use the cable connection all the time for a tv out side while ushering ant. Works great and I know I am going through booster due to fact I forgot to turn it on once and no channels as soon as switched on I had signal. Now your may vary
mshell56118 is offline   Reply With Quote
