Old 08-14-2013, 02:14 PM   #1
brockhals's Avatar
Coax?
I'd like to run a TV outside and can add a Coax outlet and run if needed. However, wondering if I'm running off my antenna, would I be able to utilize the coax input (like for a cable hookup) to run to my TV? I don't think these are directional, are they? I;m basically looking to use a port designed for input, as output for a TV.
Brock
2007 Coachmen Capri - 300QBS
2012 Yukon Denali Tow rig
brockhals is offline   Reply With Quote
Old 08-14-2013, 02:34 PM   #2
zs325RES's Avatar
I'm not sure what you are saying, but if you want to create another coaxial output for another TV, just be sure you split after the output of your antenna amp.
2013 Crusader 325RES Touring Edition
2006 Silverado 2500HD LT SW ECSB, 6L LQ4/4L80E 4.10s w/16K Curt slider (not necessary), Air Lift bags & Black Bear Performance tune & CAI
Norm & Karen Zondervan
zs325RES is offline   Reply With Quote
Old 08-14-2013, 02:42 PM   #3
brockhals's Avatar
What I'm wanting to do is use the cable input on the camper (if the site had cable, this is where it'd plug into to feed the TVs inside instead of the antenna). Use this port to plug in my outside TV if I'm using my antenna. Turning the input into an output
Brock
Old 08-14-2013, 02:48 PM   #4
Fulltime family RVer
I doubt it would work. I'm having a hard time describing why- but basically, your antennae booster has to be on for the antennae to give your TV's its signal. When you do that, it disabled the cable inlet on the side of the camper to your TVs.
Old 08-14-2013, 03:00 PM   #5
brockhals's Avatar
that's what I'm afraid of. Where is the booster typically located?
Brock
Old 08-14-2013, 03:32 PM   #6
dap
There should be three cables connected to the booster,change the center cable to the connector for a second tv and that will back feed to the outside connector .The booster is where the main tv is connected,contains a push button for the amp.
dap is offline   Reply With Quote
Old 08-14-2013, 03:42 PM   #7
vizsla owner's Avatar
I have 2 plugs in my tv area of the TT. One connects to the antenna the other to the in coming cable line.
I have ran a short piece of coax between the 2 creating the ability for me to then plug a tv into the outside (cable connection) and get the over the air signal.
03 Forest River Salem LE Travel Trailer 26BHSS
'12 Chevy Suburban w/ Heavy Tow Pkg
4 kids: G13, G12, G10, B6
2 Vizsla's Mizuno & Zeno, 1 Weimaraner Kayda
2013 Nights Camped 7
vizsla owner is offline   Reply With Quote
Old 08-14-2013, 03:48 PM   #8
I agree.
No, the coax wire is not directional, but you have to change how it's connected inside. If they put splitters on the cable-input wire that would be a problem.
Here's what the back of the antenna booster control looks like.
If there is already more than one TV in your RV then you will have a connection on the "Set 2 Output" port. You would need to add a splitter off of that to continue to drive that additional TV and also your new "outside" TV. Remove the "Cable Input" wire and put it on the other side of the splitter output (or directly on the "Set 2 Output" port if there is no second TV).
You could use an AB Switch to control where that cable goes to make it easy to reconfigure if needed.
Old 08-19-2013, 09:08 AM   #9
brockhals's Avatar
Well...didn't pick up any channels on the TV antenna. Are there any other options for this (i.e. better antena, booster, etc.). Don't want the subscription of satellite but gotta have my football this fall.
Brock
Old 08-19-2013, 09:35 AM   #10
I'll assume that you raised the antenna with the crank and then rotated it to point at the nearby TV station antennas. Did you turn the booster on? When you scanned for channels on your TV, did you select "Air" on the menu instead of "Cable"?
How far are you from the broadcast towers? If you have a smartphone, there's an app called TV Towers USA that will help you.
