Old 11-11-2014, 10:13 AM   #1
Evo2700's Avatar
Coleman 18w Solar Charger Kit
I'm considering purchasing the Coleman 18w Solar Charger Kit which includes a 7 amp charge controller. My plan is to permanently mount the panel to the roof of my trailer to keep the batteries charged while not in use. The trailer is kept at a storage lot in Vegas so it will get plenty of sun year round. I'm thinking I just need one panel to "trickle charge" the batteries while we're not using the trailer.
Has anyone used this kit or a similar one before and what were the results? I can get the whole kit for about $85. Any better price options?
Thanks!
2015 Evo 2700
2017 Ram 2500 6.4 Hemi 4.10
Evo2700 is offline   Reply With Quote
Old 11-11-2014, 10:31 AM   #2
mud yapster's Avatar
I put a 10 watt solar on my batteries to keep them charged but 10 watt didn't do much but I have a dual battery system. For long term storage I'm sure 18 watt would keep 1 battery charged but I'm sure you can get a lot bigger solar kit for $100 bucks. I'd sho p on the net. Try eBay. A bigger solar is always better and the charge controller will keep the battery from overcharging the battery. I just tried the 10 watt cause I had it in my barn already. A 100 watt will give you about 60AH of charge per day with good sun just to give you an idea of charge capacity, I hope that's right. I have 190AHs of battery in my Trailer. So you can see it would take weeks and weeks to charge your battery with an 18 watt solar cell. 30 or 50 watt would be a lot better.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 11-11-2014, 10:51 AM   #3
Evo2700's Avatar
I have two deep cycle batteries, so maybe I will do two panels. Is it as simple as more panels equals faster charging time or is it more complicated than that?
2015 Evo 2700
Old 11-11-2014, 10:52 AM   #4
It depends on if you are using a battery disconnect or not. If you use a battery disconnects and you just want to keep the battery topped up from self discharge you will be fine. If you plan an having other thinks running then you will have to do some math to figure out what your current drain is.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 11-11-2014, 10:53 AM   #5
Simple as that.
Old 11-11-2014, 10:56 AM   #6
Evo2700's Avatar
Thanks! My wife says I'm hard to shop for at Christmas time, I'll point her in the direction of some solar panels
As far as I know, my trailer doesn't have a battery disconnect.
2015 Evo 2700
Old 11-11-2014, 11:00 AM   #7
Just remember that the 18W panels will only give you 12W (1A) of charging max with the simple charge controller they include. That charger will just disconnect the batteries from the solar panel at 14.2V (I think) and back on at 13.6 (I think). I have some of these panels and I am lucky to see 0.75A out of them.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Old 11-11-2014, 01:11 PM   #8
Evo2700's Avatar
I ordered two panels and the controller. We will see how it works. I should be OK as my intent is just to maintain while not being used at the storage lot.
2015 Evo 2700
Old 11-17-2014, 04:51 PM   #9
Evo2700's Avatar
Panels are installed. The controller is mounted inside a cubby hole above the fridge, which we never use to store anything anyway. I'll let you know how well it keeps the batteries charged.
ID:	66542   Click image for larger version
2015 Evo 2700
Old 11-17-2014, 06:54 PM   #10
Good job, they will keep your batteries topped off while not in use. I'm wanting a little more power like two 120watt panels with a more efficient controller to keep mine recharged during 1 days Sun. That way I can drain the 2 batteries during the night with the heater and the next day they can replenish for the next go round. That's an nice setup you have to maintain them. I'm kinda scared about putting screws thru my roof to mount them. I have good sealant so I guess it won't hurt anything.
solar
