Old 12-26-2015, 01:03 PM   #11
Who Dares, Wins
doc73's Avatar
Yes, people do use them as a good geni hookup for a power failure.. They need to use a cord known as a "suicide cord" since it has two males. They are widely debated but works.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is online now   Reply With Quote
Old 12-26-2015, 03:59 PM   #12
Left Coast
No desert codes here.....using 2 of 'em
Old 01-06-2016, 12:28 PM   #13
Do you mean that I could supply house power in case of failure with 2x 50amp males ??? I thought there was a cut off ?? or do I need to install wire and female 50 amp directly on generator if i want to supply house in case of failure ??
2016 Spartan 1234X Trail-Air Pin Box...thermo windows...12 cu.ft frig....3 seasons patio door
2011 Ford F-250 Super Duty Power Stroke King Ranch 4X4 diesel
Pierre Allard is offline   Reply With Quote
Old 01-06-2016, 12:41 PM   #14
Who Dares, Wins
doc73's Avatar
Not quite sure what you mean by installing a female hookup on a geni but some already have a 30amp twist lock plug.
I do not agree with doing it but google a suicide cord or back feeding and you can make your own decision how to precede. Not safe IMO but we are all adults. But short answer is using a 30amp twist lock on the geni you can back feed a dryer outlet (well honestly any outlet but expect to burn the house down) to power a home (well half if only using a 15 or 20amp outlet). But do not do that or you will burn down your home.
2015 ChevyHD D-Max
Old 01-06-2016, 12:53 PM   #15
my onan 5.5 do not supply power to the power cord that connects to shore power when running and if i need power to house that is already equipped within the electrical house panel with a breaker in case i want to hook a generator. So if i want the rv onan to supply the power i need to wire directly on the generator? So if i do that i would need to install a female connection on generator and use a suicide cord ? Right?
Old 01-06-2016, 12:58 PM   #16
OntarioFireFighter's Avatar
There's no debate - they are an absolute code violation, and a safety hazard...
2014 Grey Wolf 28BH, behind a 2015 F350 Diesel Crew Cab
Nights Camped 2016: 44
Nights Booked 2017: 11
Nights Camped 2017: 6
OntarioFireFighter is offline   Reply With Quote
Old 01-06-2016, 01:21 PM   #17
I really cant believe that the Moderators have let this (UNSAFE/LIFE THREATING) Post to go on this Long! This type of Crazy practice CAN/WILL KILL Power Company People as well as Burn down Homes! Youroo!!
Old 01-06-2016, 02:10 PM   #18
Who Dares, Wins
doc73's Avatar
Oh, I agree... But like the last thread on this some months ago... People will do stupid things regardless of the rules (case in point weight police threads). I have a home generator that I wired to a transfer switch this is the correct, not as cheap method, but my home is safe and will not burn to the ground...
I was actually surprised my home was built with a switch between the heater and the breaker box. An outlet was then between the switch and the furnace so a suicide cord could be used to power the furnace in an outage. I was shocked that was even allowed to be put there.
Pierre, My recommendations... Do it right. If you need to ask on here it is probably outside your scope. I ran extension cords until I could pay to purchase the right parts to hook a transfer switch in.
Ask an electrician to see how and IF it can be done safely. Half assing it might get you hurt or killed!
2015 ChevyHD D-Max
Old 01-06-2016, 02:11 PM   #19
Flybob's Avatar
Suicide cords are illegal in every state in the US and pose a significant danger to the user and power company employees. If there is an accident as the result of use of a suicide cord, you could be held liable. It is strongly recommended that you do not use them.
Please do not promote them on this forum.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 01-06-2016, 02:12 PM   #20
MNtraveler's Avatar
Please, please, please do not do this. You can kill someone, or multiple people.
Moderators, please put this thread out of its misery!
Land of 10,000 Lakes
2016 Forester MBS 2401R
2016 Forester 2401R
MNtraveler is offline   Reply With Quote
power
