Old 04-28-2015, 11:19 AM   #11
Originally Posted by Bianchina3 View Post
I feel like a complete idiot. It was hooked up backwards! DUH!
I hope I never do but nobody's immune to stupid camper tricks.
Perhaps some bright red paint on one end of the battery would help?
- 1969 Coleman Williamsburg (with original canvas!)
- 2000 Coleman Mesa
- 2014 Shamrock 21DK
- 1999 Chevrolet Astro
- 2005 Dodge Durango Limited 4x2 5L V8 Hemi
- 2016 Ford F-150 SCrew Lariat 4x2 3.5L V6 Ecoboost
chriscowles is offline   Reply With Quote
Old 04-28-2015, 11:49 AM   #12
2016 Shamrock 183 Hybrid
Live and learn....live and learn.
sparty047 is offline   Reply With Quote
Old 04-28-2015, 12:41 PM   #13
TURBS's Avatar
Originally Posted by Charles Firth View Post
I was not aware that you were shorting out the converter when the battery is connected backward. I just put my fully charged battery back in the Jammer,as a test I operated the jacks, and found that the polarity was reversed. Pushing the up button was down, so I reconnected it and they work like they are supposed to. I need to mark my cables. hope I have not caused damage. Everything seem to work ok, except my radio.
There's an inline fuse behind the radio.
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 04-28-2015, 12:42 PM   #14
TURBS's Avatar
Common mistake.
Black in this case is positive not negative.
TURBS
Old 04-28-2015, 12:46 PM   #15
Originally Posted by TURBS View Post
Common mistake.
TURBS
The positive battery cable is black? Why would they do that?
Iwritecode is offline   Reply With Quote
Old 04-28-2015, 01:01 PM   #16
pkenley's Avatar
Used my wife's red fingernail polish to color the positive terminal and some red tape on the cable.
Phil & Carla Kenley
2014 Rockwood ROO 21ss
2013 Ford 150 Platinum Crew Cab
(Looking at the Georgetown 329DS)
Nights camped in 2011/16; 2012/15; 2013/48;
2014/10; 2015/101 2016/55 yr to date
pkenley is offline   Reply With Quote
Old 04-28-2015, 01:47 PM   #17
TURBS's Avatar
The ground is white.
TURBS
Old 04-28-2015, 01:55 PM   #18
TGR
TGR's Avatar
It is the normal trailer wiring convention to have the black wire positive and the white wire negative for the battery connections with the negative circuit tied to ground.
This can be confusing because in modern automotive wiring red is to the battery positive terminal, black is to the negative terminal with the negative circuit tied to ground.
To confuse things further, AC electrical wiring has black the “hot” wire and the white wire is “neutral,” which is tired to ground at the source wiring panel.
Lastly, in electronics, the black wire is for the common circuit, usually ground.
If there is a convenient place near the battery to use a sharpie, write down “White to Batt. Pos. (+)” and “Black to Batt. Neg. (-).”
2015 Wildcat 282 RKX
2011 F350 Lariat, 6.7 L. Diesel, 8 ft., SRW, Reese R20
TGR is offline   Reply With Quote
Old 04-28-2015, 02:02 PM   #19
This is one reason that I wish the manufacturers of ALL types of trailers would just send someone from each manufacturer to a meeting and they would decide which color wire to use for each circuit. My old TT did indeed have a black wire to the battery positive (+) and a white wire to the battery negative (-). My newer TT has a black wire to the (+) also but there is about four (4) inches of red shrink wrap on this black wire right at the terminal. The newer unit also has the white for battery negative (-). My cargo trailer has a red wire from the battery positive (+) to the circuit terminal and a black wire from the battery negative (-) to the circuit terminal. One thing I was going to mention as to the original posters message: I used to work in a plant that made lead/acid battery's. There was constantly about 3% of the battery's we made that had the terminal's reversed. There was a test machine which tested each battery made but for some reason it missed those 3% that got through. Many were later caught in manual battery voltage testing for QC.
Thurman is online now   Reply With Quote
Old 04-28-2015, 02:50 PM   #20
You are not an idiot, we have all done DUH things!!!
saltyman is offline   Reply With Quote
battery
