Old 04-28-2015, 03:04 PM   #21
Happens to the best of us at one time or another. Whether we care to admit it or not.
Glad you figured it out. Go have some campin fun.
JoeNanMinn is offline   Reply With Quote
Old 04-28-2015, 03:05 PM   #22
spierce617's Avatar
To bad Forest River does not add this sticker to all of the units that are wired this way.
1999 Chevrolet Suburban 5.7L V8
2005 Cherokee Lite 28A
spierce617 is offline   Reply With Quote
Old 04-28-2015, 04:37 PM   #23
Originally Posted by TGR View Post
If there is a convenient place near the battery to use a sharpie, write down “White to Batt. Pos. (+)” and “Black to Batt. Neg. (-).”
NO! Other way around.
Black is positive (+)
White is negative (-)
johntaylor is offline   Reply With Quote
Old 04-28-2015, 04:48 PM   #24
dcheatwood's Avatar
Originally Posted by saltyman View Post
You are not an idiot, we have all done DUH things!!!
Yep. And another pricey mistake avoided by the wealth of info on this forum.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 04-28-2015, 09:23 PM   #25
It is the normal trailer wiring convention to have the black wire positive and the white wire negative for the battery connections with the negative circuit tied to ground.
On my 21DK, FR used red for positive and white for negative on DC circuits. White is grounded at the frame and red goes to the circuit breaker under the front of the trailer.
That's true at the battery. Internally they use two-conductor wire that looks like lamp cord but probably is heavier gauge. It's white with a red (or other color) stripe, the stripe side going to the fuse and the white going to the common ground block.
- 1969 Coleman Williamsburg (with original canvas!)
- 2000 Coleman Mesa
- 2014 Shamrock 21DK
- 1999 Chevrolet Astro
- 2005 Dodge Durango Limited 4x2 5L V8 Hemi
- 2016 Ford F-150 SCrew Lariat 4x2 3.5L V6 Ecoboost
chriscowles is offline   Reply With Quote
battery
