Old 09-05-2012, 12:49 PM   #11
Being electrically challenged, I just put a toggle switch on the 2 outside fans and a toggle switch on the 2 inside fans. Turn the frig on, flip 2 switches, turn the frig off, flip 2 switches. KISS principle with my limited knowledge.
Old 09-05-2012, 12:51 PM   #12
Originally Posted by TexasBBQ View Post
John - nice work. I'm curious why you chose 4 fans. Is it based on what you had or did you run some tests?
I had used other fans from that supplier and found that they
were always great performers and decided to chance it based
on specs.
From a previous thread, some folks thought that computer fans
would be way too loud for the application, so I was prepared
to move on to more expensive ones. But, they are really very
quiet, much quieter than I expected, so I decided to go fer it
with them.
I did no testing of the fridge venting, but depended on the results
posted by others here with similar systems. I do not expect problems
when I install them. Others have had good results with fans........
I did test the fans down to 5.25V, but have no tachometer to check
speed or airflow meter to check flow. Just winging it.....
cheers,
johnd
2001 Cherokee CKT27X - 2005 Chev 3500
Sara, John & Crafty Canines - Coco and Cole
Medical research shows that men have a "biological clock" too. The older we get, the greater the NEED to drive a TRUCK!
dnaraG_1M is offline   Reply With Quote
Old 09-05-2012, 12:54 PM   #13
Malco's Avatar
I had originally planned to put a toggle switch on mine but was trying to think of a place that wouldn't look like I just stuck a toggle switch on.Now with turbo going to post pics I'll be able to make it look factory,tell my wife I thought of it,and have her think I'm smarter than I am.It's a pretty good day.
2011 Salem 30kqbss
2013 Ram 2500
2005 Ram 2500
1968 Pontiac Le Mans
Malco is offline   Reply With Quote
Old 09-05-2012, 12:57 PM   #14
You bet.
When it works for you, simple is always best.
cheers,
johnd
Old 09-05-2012, 02:39 PM   #15
lindy's Avatar
DUNNNC; I keep it even simpler, I have a 120v, 12" box fan that I set against the refers outside air vent and turn it on. My cooling fan on the back of the fridges coils never somes on and it drops the inside temp about 15 degrees. Cost $3 at yard sale.
2012 Winnebago "Journey To Insanity" 40U
2008 Dakota Sport 4x4
2004 Subaru Baja - DW's
2006 Honda Shadow Aero - TOAD for now.
F.R.O.G. member
lindy is offline   Reply With Quote
Old 09-05-2012, 02:58 PM   #16
I understand, but you have to store the fan and run an extension cord.
Old 09-05-2012, 05:57 PM   #17
lindy's Avatar
DUNNNC: fan cord plus in right where it sets no ext. cord needed, and fan weight maybe 2lbs, all plastic - made in CHINA? and is only a 12" box fan no sweat, and if there's sketters around I turn it to blow in our direction and chase them away
F.R.O.G. member
Old 09-05-2012, 06:00 PM   #18
OK, concede the extension cord, but it has to be stored!
fan
