Old 02-22-2016, 10:53 AM   #11
Originally Posted by ScottBrownstein View Post
I would be extremely surprised if the factory would install a 1,000 watt inverter feeding a 1200 watt, 65 amp converter. That is what I think 35RLs have. It would run for a second and immediately shut down!
Who has a 35RL? I have a 55amp converter but soon to be a 70amp converter
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 02-22-2016, 11:07 AM   #12
Medic97's Avatar
I do have an inverter and was told by service during PI that inverter will provide a trickle charge to the batteries as well as keep residential fridge running during travel. Is this not the case?
Robert & Wendy M
5er: 2016 Columbus 320RS - TV: 2015 F250 6.7L V8 Diesel
Part-timer; Looking forward to fulltime...
Medic97 is offline   Reply With Quote
Old 02-22-2016, 11:10 AM   #13
fonzie's Avatar
Not the case, it won't provide trickle charge to the battery, that should be achieved by the truck 12 volts charging supply.....
Fonzie
Old 02-22-2016, 11:58 AM   #14
Head Rambler
The inverter charging the batteries powering the inverter! Sounds like a perpetual motion machine! I'd like to have one of those.
Gotta go campin!
Old 02-22-2016, 12:52 PM   #15
TURBS's Avatar
I have doubts inverter is hooked to converter.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 02-22-2016, 02:07 PM   #16
Medic97's Avatar
Thanks Fonzie!
Robert & Wendy M
Old 02-22-2016, 02:38 PM   #17
wmtire's Avatar
Ok, the site team did a little edit on a few posts. We can play a little nicer than that since we are all buddies here. We are all here to help and learn, so let's please not lose sight of that.
I personally believe that a few subjects may be getting confused, as there are RV's that have only a converter, some that have both a separate converter and inverter, and some that have a combination inverter/charger.
Here are some schematics concerning the separate converter and inverter, and then the combination inverter/charger. As stated in the schematic for the separate converter and inverter, if there is no power from either the generator (if equipped) or shore power, then the link is broken going to the converter, so a properly wired RV will not have the converter powered by the inverter.
This information may be found here, along with much more good reading.
RV Electrical Systems
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 02-22-2016, 03:22 PM   #18
Kenny kustom's Avatar
There's also converter in board or outboard from your dist panel.
2016 Sabre 36QBOK
2015 Ram 3500 CUMMINS
2017 Dynamax Isata 4
converter
