Old 02-21-2016, 07:24 PM   #1
Converter
I have owned 5 campers so far and I had never given it much thought but when getting ready to tow the camper I had always turned the things off at the breaker box but I had never turned off the converter. It has finally dawned on me that leaving the converter on is bad. We stop and eat or stop at Walmart and buy food and all the while that converter was trying to charge the batteries off battery power, just killing the batteries. I had never given it much thought until I was reading on this forum.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 02-21-2016, 08:23 PM   #2
The converter does not run off the batteries. It only operates off of the 120V AC input. There is no battery input to your converter.
David, Sherry and our three fur kids, Nicholas, Finnegan and Bentley
2013 Coachmen Encounter 36BH
2014 Honda CR-V/ Blue Ox Autostop
DSurette is offline   Reply With Quote
Old 02-21-2016, 08:27 PM   #3
TURBS's Avatar
Converter
Spock123 unless you are plugged into shore power your converter does nothing.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
Old 02-21-2016, 08:27 PM   #4
Who Dares, Wins
doc73's Avatar
No but if you have an inverter installed (say a residential fridge) that does change it to what spock is saying if you hook it up that way . I am sure the inverter is not wired to the battery convertor on the 120 side but if one made a hook up this way it does make a weird loop on the system.
Sent from my SAMSUNG-SM-G870A using Tapatalk
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 02-21-2016, 08:29 PM   #5
I have a 1,000 watt inverter and it will send power to the converter.
Old 02-21-2016, 08:32 PM   #6
TURBS's Avatar
Why is your inverter hooked to your converter?
2015 Columbus 320RS
2008 2500HD Duramax
Old 02-21-2016, 08:35 PM   #7
Who Dares, Wins
doc73's Avatar
Hmm.. Interesting. Factory?
2015 ChevyHD D-Max
Old 02-21-2016, 09:06 PM   #8
sgtlm17's Avatar
You never have your inverter run your converter. This causes a bad electrical loop that will kill your batteries. This is a RV no no.
2016 Forester GTS 2801QSF
sgtlm17 is offline   Reply With Quote
Old 02-22-2016, 05:57 AM   #9
fonzie's Avatar
Usually if you have a factory inverter it is to feed the optional residential fridge only and will not feed converter....
Fonzie
Old 02-22-2016, 06:08 AM   #10
I would be extremely surprised if the factory would install a 1,000 watt inverter feeding a 1200 watt, 65 amp converter. That is what I think 35RLs have. It would run for a second and immediately shut down!
2015 335DS
ScottBrownstein is offline   Reply With Quote
converter
