Old 01-04-2014, 11:11 AM   #1
Location: New Hope, 25 mi east of Starkville and 50 west of Tuscaloosa on the state line.
Converter 8955PEC blowing fuse for 110v
2009 Rockwood, while camping I lost the 110v plugs in the kitchen area along with the 110v lighting in kitchen area. Changed 15 amp fuse (second position) identified in panel "KIT". Back home, keeping camper fully powerd from house I check to find the fuse blew again. This time while replacing it sparked and blew (2 more) when trying to put it in. I have checked all wiring to the plugs and lighting affected and no issues. HELP
morg61 is offline   Reply With Quote
Old 01-04-2014, 11:16 AM   #2
TURBS's Avatar
Your 110 plugs are controlled by one or more gfci plugs normally in the bathroom and or kitchen.
They should not be controlled by said fuses but instead by a normal household circuit breaker.
You may have two or more issues going on.
TURBS
BIRTHDAY BOY
Old 01-04-2014, 11:23 AM   #3
You are correct, GFCI in kitchen, operating with a heater plugged in and night light in the bathroom plug lite. They have a different connection the converter / power source. I appreciate the input, please keep it coming.
Old 01-04-2014, 11:27 AM   #4
TURBS's Avatar
What are the fuses that are blowing controlling?
Are they listed?
TURBS
BIRTHDAY BOY
Old 01-04-2014, 11:54 AM   #5
Opening door on converter it shows "KIT". Only the 2 110v plugs (not GFCI plug) 2 110v lights and the exhaust fan over stove are not working without this fuse.
Old 01-04-2014, 11:58 AM   #6
Dave_Monica's Avatar
The kitchen lighting would be 12V DC as was the 15A fuse you replaced. If it blow the fuse every time, you must have a short somewhere in that circuit. The kitchen plugs are 110V AC and wouldn't be related to the lighting problem.
Dave
Old 01-04-2014, 12:31 PM   #7
Dave you are correct, just plugged a lamp in and yes the 110v plugs are working and I confirmed the other ights all have a 12v type bulb. So I have a short in that circuit somewhere.
Old 01-04-2014, 12:48 PM   #8
I'd be guessing that the short is in one of the light fixtures. You could try to determine which one by disconnecting the wiring to one of the fixtures and seeing if the fuse blows...process of elimination. If it's one of the light fixture and it's not obvious or correctable, they're not expensive to replace.
Dave
Old 01-04-2014, 02:22 PM   #9
Dave that will be my plan, I have already checked one and will continue down this path. Appreciate everyone's input.
As they mentioned "Rookie" to this Forum stuff but I already like it and appreciate the responses
Old 01-04-2014, 03:51 PM   #10
TURBS's Avatar
When you get the issue fixed please report back.
Pictures of issue are always nice.
After that your always welcome to participate in all forum Areas!
We'd be glad to have your input on things as well.
TURBS
BIRTHDAY BOY
110v, converter, fuse
