Old 11-22-2015, 07:17 PM   #1
Anyone know what happens when you a bad converter or what some signs it is malfunctioning
garywinger is offline   Reply With Quote
Old 11-23-2015, 07:32 AM   #2
waiter21's Avatar
House battery doesn't charge when plugged into shore power (or on generator).
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2001 Civic
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 11-23-2015, 09:36 AM   #3
Do you have a multimeter and are you plugged into good shore power. If your converter is working well you should get a voltage of 13.2-14.4 depending on state of batteries.
2011 Wildwood T26BHXL
2004 Yukon XL Denali
43yrs of camping; one lucky guy
YoungKopernik is offline   Reply With Quote
Old 11-23-2015, 10:22 AM   #4
bubbles's Avatar
Typically, if you are connected to shore power and have a battery disconnect; switch to disconnect and you will know if the converter is working.
Old 11-23-2015, 10:26 AM   #5
TURBS's Avatar
Your battery will go dead and you'll not have any 12v power in the camper.
You may also see lights dimming then bright then again dim .
Old 11-23-2015, 06:06 PM   #6
dwhit's Avatar
Location: Chicago, Rochester now GA/SC at Lake Hartwell
A voltmeter is required equipment for camping in an RV of any size.
My converter hums...way-huge irritating...but it's working.
2014 XLR 415AMP, 2011 F350 Lariat 6.7 DRW, three bikes, NRA Benefactors.2013=180, 2014=184, 2015=216, 2016=220 jus' completed 7300 mile trek.
dwhit is offline   Reply With Quote
Old 11-23-2015, 06:17 PM   #7
Always room for one more tool !
mfMcFroggierPod is offline   Reply With Quote
Old 02-18-2016, 09:39 AM   #8
SeaDog's Avatar
I'm going to add what I did when my converter quit while on a trip. I lost all 12V when the batteries went dead so I took my portable 12V charger and connected to my batteries plugged into the 120v outlet on the coach and had 12v back, replaced the converter when i got home.
Retired Navy
Jake my sidekick (yellow Lab)
2006 F350 6.0
2016 Flagstaff 26 FKWS
AF&AM of Idaho
