Old 04-16-2019, 09:14 PM   #1
rcarbaugh524's Avatar
Converter ??? Battery????
So.......not sure if we have a battery problem or converter problem. We leave our camper plugged in all the time. Sometime ago the power came unplugged from the house to the camper. Plugged it back in and the lights are very dim. Would not slide the slide out or work the a/c. Finally after a couple hours we could is the slide and a/c. Left it plugged in and fast forward to today (4 days). Dim lights and canít work the slide again. I plug the camper in my truck and all is fine when I unplug shore power. No no shore power connected and disconnected from the truck and there are no lights. Battery or converter? All breakers are on and all fuses check good. Need some help. Camping tomorrow!!!!
rcarbaugh524 is offline   Reply With Quote
Old 04-16-2019, 09:15 PM   #2
Oops sorry. Camper is a 2017 greywolf 29te
Old 04-16-2019, 09:37 PM   #3
What is the voltage at the output of the converter and at the battery?
2017 Coachmen 233RBS
2018 Ford F150 Lariat
"Common sense is not very common"
babock is online now   Reply With Quote
Old 04-16-2019, 10:10 PM   #4
bikendan's Avatar
How long was it unplugged?
Clearly the battery was drained low enough to kill it, due to the parasitic power drains. It needs to be fully recharged and tested, preferably with a hydrometer. It may have a bad cell so it may not hold a charge.
Equalizer WDH
Old 04-17-2019, 07:47 AM   #5
for sure it sounds like you have discharged the battery. pull them out, take them to an auto parts store, and have them tested. plug in to shore power and see if you have lights. if so, your converter is probably working. if not you may have blown the fuses on the converter. check them.
as mentioned previously, it would help if you took voltage readings and reported them to give a better indication of what is going on.
2015 cardinal model 3825fl
2015 dodge ram 3500 dually
CHICKDOE is online now   Reply With Quote
Old 04-17-2019, 07:58 AM   #6
Flybob's Avatar
Another option.
Depending on how long the RV sat without power, you may have completely depleted the battery. When you plugged it back in the charge current to the battery may have been high enough to blow the reverse polarity fuses. If this is the case you will have no power when not on shore power. The fuses may either be in the distribution panel or on the back of the converter and are usually 30-40A ( orange, brown). If these are OK, you should also check the resettable breaker near the hitch. see photo below. Push button on side.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-17-2019, 08:31 AM   #7
kenandterry's Avatar
Going back to where the OP stated that ďsometime ago the power came unplugged from the house to the camper.Ē
Therefore, no one knows how depleted the batteries drained, and in fact may not be recoverable. Iím not sure if the location for the trailer is within eyesight of the house, but hereís what I do.
Our rig is plugged in. I have a night light plugged in and sitting in the window of the RV visible from the house. It only comes ON at dark. Itís an easy check to see that the power is still connected to the rig. No surprise if thereís no power to the rig such as what appears to have happened to the OP.
Ken and Terry
2010 Georgetown 330TS being pushed by our
2017 GMC Terrain toad (4 wheels down)
kenandterry is offline   Reply With Quote
battery, converter
