Not sure what brand converter you have. The WFCO in my newer trailer states it is a 3 stage unit based on battery voltage when pluged in. I purposely drew down my battery state of charge, but, did not see any voltage change.
I purchased an IOTA with an IQ4, and it will chnge the output voltage and act like a true charger.
I play with a lot of 12 volt stuff on my wokbench, so I set up a connection point at my bench using the IOTA as a power supply. Much easier than hauling a battery around.
With the IQ4 unplugged, i get a constant 13.4 volts.
2018 Surveyor 264RKLE
Retired
Location depends on weather and state plandemic rules.
Most coincidences are carefully planned
