Old 05-30-2017, 08:24 PM   #11
Check for bad connections.
Also: confirm your NOT running your refrig on DC
Did you try to connect converter directly to battery? This would eliminate camper systems as fault= troubleshooting.
mfMcFroggierPod is offline   Reply With Quote
Old 05-31-2017, 06:58 PM   #12
srcpaid's Avatar
No loose connectors, not running frig on 12v, and converter output terminals showed 0 volts output. Each tech confirmed the converters were dead, both in field and at dealer.
srcpaid is offline   Reply With Quote
Old 06-01-2017, 04:34 AM   #13
Has the 120v A/C feed circuit been tested for faults to the converter?
converter
