Originally Posted by Jay2504
I am also lucky that I have no underbelly cover. You can see the wiring running along the frame. I only used 4/0 cable because I had cable that size with pre-made eyelet ends laying around from work. If I had to buy cable I would have done number 2 or 4. The only INverter that I am currently using is 300 watts for the tv, so I guess the max amps going through those cables would be the 55 amps put out by the converter at full charge if it ever got there. Jay
Jay, If this is WAY more than you need, I apologize in advance.
OK, lets talk power here.
The "INverter" will only be drawing its amperage from the battery (not the 55 AMP CONverter) because why would you be using it if your camper's outlets are "hot" with shore power (needed to power the "CONverter").
When connected to shore power with dead batteries, the maximum charging current of 55 amps would only last until your batteries got to about 50% capacity, then the converter will switch to stage 2 and drop the amperage considerably (like down to 8 amps or so).
When Boondocking, the INverter will draw what it needs (as long as the battery can provide it) to produce its rated power (in your current case 300 watts of power). Remember that Watts is Watts (AC Watts are the same as DC Watts - ignoring minor losses in the INverter making them).
Power = Amps times Volts
300W = ? times 12 volts
Solve for Amps ( P/V = A) and you get
300 divided by 12 or 25 amps coming from the battery at full rated 300 Watt inverter power.
A 300 Watt INverter willpower a computer, some TVs, or charge a cell phone, and perhaps a combination of those depending on power draw (in AC Watts).
Required minimum wire size depends on the maximum FUSED length of wire required between the battery and the INverter and the maximum FUSED amperage required to produce the maximum rated INveter power.
Using this chart:
https://www.bluesea.com/resources/1437
From the chart for (say) a 20 foot run of wire from the battery to the INverter (with no more than a 1 volt loss in the wire), and wire fused for the maximum required current of 25 amps, would require a wire diameter of only 12 gauge. Note that that same inverter located 30 feet from the battery would require you to increase the wire size to 10 gauge to keep the volts lost in the wire to a reasonable amount.
A "normal size" Group 24 Marine Type Dual Purpose battery is rated to provide about 70 Amps per hour (defined as total amps available over a 20 hour period) or a 3.5 amp load will kill that battery in 20 hours (3.5 times 20 = 70).
I gather that one day soon (since you have 3 Group 31 batteries - God bless you!), you will be adding a bigger INverter to run more stuff.
A Group 31 battery has (depending on manufacturer and construction) between 95 and 125 AH of capacity. So for calculation purposes lets use 100 amp hours each, for a "bank" of 300 AH. A 100AH rated battery will provide 5 amps of current for 20 hours (100AH).
Your 300AH Bank, putting out the 25 amps demanded by your 300 Watt inverter, would last 300/25 or 12 hours at that load (disregarding something called the Peukert Effect).
So since you have this monster battery bank, you decide to increase your INverter size to 3000 watts (thinking you can run your AC or something!).
Now you need 3000/12 or 250 amps of DC power to feed that INverter. 300/250 is about 1.2 hours (Totally ignoring the Peukert Effect at that delivery requirement). Your 4/0 wire would be perfect for 20 feet or less to carry that potential maximum load!
Realistically, your setup would work best with a 2000 Watt INverter and you should be able to run a coffee maker and watch TV while it is brewing.
Normally, you would still need to fuse the INverter for its maximum load of 2000/12 or 166.66 amps (rounding down) 150 amps. 150 amps will deliver a reliable 1800 watts without blowing the fuse. A 150 amp load only requires 1AWG wire (again with no more than a 1 volt wire loss) and you have 4/0. I would have no qualms at that wire size to fuse at 175 amps, but realize that your INverter would trip offline first if you overload the inverter's circuit.
Now, if you do use a 1500 watt coffee maker, how long will your batteries last making coffee? Great question! (Again ignoring the Peukert Effect)
Say your coffee maker runs for 15 minutes to make a pot of coffee.
1500/12 = 125 amps times .25 hours = 31.25 AmpHours.
Your 300 Amp Hour Battery bank is capable of making about 10 pots of coffee (again ignoring the Peukert Effect) before your batteries are dead.
Hope this helps!
Herk
If you decide to "go big" I highly recommend looking up the Peukert Effect as it will have a big impact on battery life at those higher power draw numbers.
