Converter fans running when on shore power
Hi Guys and Gals. I am a newbie to this forum but have rv'd (full and weekends) for30 years. I ran into a new concern and need help from the pros out there. Bought a little trailer and the batteries would not charge when on Shore power. I went and took the cover off of the elec panel to look at things and found a bad fuse at the converter. Put in a new one and BAM! everything charging up perfectly however....the neg. post on one of the batteries was getting pretty warm so I cleaned all the terminals and lugs off and the heating disappeared, HOWEVER, then as I was overjoyed with my work, I heard the fans at the converter going. Is it normal that the fans run when the converter is plugged into shore power? I'm hoping so, kinda like the fans in a computer always running to keep things cool. Your input is more than welcome and THANK YOU!
