Old 07-24-2016, 07:19 AM   #1
Converter issue
I have a 2013 Palomino Stampede and while camping this weekend the main electrical panel started smoking. I immediately unplugged everything. None of the AC or D.C. Fuses blew.
It has a WFCO WF-8900 distribution center.
AC was set to 70 and nothing being overdrawn from the AC circuits.
I am thinking the converter went.
But why? Are there any issues or recalls that I can find out about? This is only maybe 3 seasons old.
jchiar is offline   Reply With Quote
Old 07-24-2016, 07:47 AM   #2
SeaDog's Avatar
Converters are like any electrical equipment sometimes they just give up the ghost have to stop here pop-up is killing my typing
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
AF&AM of Idaho
Old 07-24-2016, 08:03 AM   #3
AquaMan's Avatar
The WFCOs have been known to do exactly that. When replacing, I would go with a Progressive Dynamics. Much better quality and charging features. Many will replace the WFCO right off the bat and keep it as an emergency backup, knowing that it will eventually quit.
2016 Georgetown 364TS
Nights Camped
2014 - 56
2015 - 41
2016 - 81
Old 07-24-2016, 08:20 AM   #4
When you replace your converter, take the time and effort to relocate the converter within several feet of your battery bank. It will recharge your batteries faster. Not a requirement if you never dry camp.
Skyliner is offline   Reply With Quote
Old 07-24-2016, 03:02 PM   #5
When you replace it with the progressive dynamics unit, where would you mount it? I am guessing it won't fit in the existing black box. Guessing it still needs to wire to the existing D.C. Fuse panel. Thanks
Old 07-24-2016, 03:31 PM   #6
I would mount it as close as possible to the battery and run the pendant inside,
Old 07-24-2016, 03:38 PM   #7
Sorry what's the pendant?
Old 07-24-2016, 09:02 PM   #8
I read the Progressive Dynamics is a swap in replacement. Does it literally go where the other one was?
Old 07-24-2016, 11:42 PM   #9
Charge Wizard PD92201 Remote Pendant
Many factory converters are integrated with the ac and dc power distribution panel. There is usually enough room to install one in the space where the power distribution panel is located.
However, as stated, it is best to mount it next to the battery not 15-25 feet to the rear of them.
Plenty of you tube videos on replacing one. Make sure you disconnect the battery(ies) before you attempt.
Old 07-25-2016, 05:59 AM   #10
TURBS's Avatar
Converter issue
Yes progressive makes a drop in replacement.
Boondocker also makes a drop in replacement
http://www.bestconverter.com/55-Amp-...l#.V5XwvfQ8LCQ
http://www.bestconverter.com/PD4655T...l#.V5Xw7fQ8LCQ
I recommend the boondocker if you go with the drop in replacement.
2015 Columbus 320RS
2008 2500HD Duramax
2015 nights camped "34"
2016 nights camped "14"
converter
