OK, you found the converter. Fuse or fuses? What are you pushing in? You plugged something in and it worked. Assuming it was a 120v something, that means you have shore power. Then you say the AC will not work so must assume you mean A/C as in Air Conditioner. Also Fridge does not work. Both the A/C and Fridge require 12v to work electrically. So that means you have no 12v power. Soooooo, suggest you get a charger on your batteries ASAP so you don’t kill them.
Mike Dropped
