Old 06-23-2012, 02:19 PM   #11
Glenn5995's Avatar
Our power center in the fifth wheel has a three-stage charger as probably every RV for the past decade or more, but it still takes a long time to recharge our batteries. I don't know how much of an improvement would be achieved with an upgraded power center, but at present our stand alone charger will recharge much faster.
Glenn & Beth (Dad & Mom)
David & Audra (16 year old twins)
Glenn5995 is offline   Reply With Quote
Old 06-23-2012, 06:19 PM   #12
Herk7769's Avatar
Thank Glenn. You did a fine job with covering for me!
To clarify what I was saying; due to the weight of my generator it "lives" 24/7 in the bed of my truck. I pay for that with increased weight of the TV; reduced towing capacity (payload) and wear and tear on the generator when I am not actually using it.
However, since it is there; I take advantage of the benefits when I can.
1) I also carry a pancake 110AC compressor that can run my air tools, grinder, and inflate tires while at rest stops if needed.
2) At rest stops I can quickly connect power and run my microwave and air conditioner.
3) I have the ability to "boondock" on the fly if I show up unscheduled at a campground and they can't place us right away. Spent more than one night in the parking lot of a KOA that had a bunch of their sites washed out in a downpour.
4) I can charge my battery using my Ship-N-Shore charger. By disconnecting the battery bank I can use all four stages of my Ship-N-Shore to desulphate and fast charge when boondocking or if there is a power failure (or bad power) at the campground.
Since the generator is available all the time, it seems silly not to have a good quality 4 stage charger as well. When using the SnS charger you must remove the caps and watch your water levels. It can really heat up the battery when using the fast charge or desulphate feature.
HAM CALLSIGN - KC3FFW
Old 06-23-2012, 10:25 PM   #13
textman's Avatar
All A/C items work. The converter is WFCO 65. It is at the dealer now, so the warranty should cover it... Just a bummer it was the 2nd trip out. Where is the quality control these days?
2012 Cedar Creek 36B4
2007 Ford F-350 Dually Crew Cab 6.0 Studded w/EGR Delete
Loving Life
textman is offline   Reply With Quote
Old 06-26-2012, 12:10 AM   #14
Glenn5995's Avatar
Hopefully they get it all squared away for you.
Old 07-04-2012, 10:16 PM   #15
Ok so my 365saq is hooked up to 30 amp today and appears my battery isnt charging....only thing working is AC.....fuses are fine.....have a battery charger hooked up for the lights......everything worked on 50 amp a few days ago......the only thing is a TV blew in the back room while hooked up to 50 amp and i was raising lowering front jacks..... interior light of microwave is on when i open the door.....but faceplate isnt working....any battery reset button on this model? Anyone else get this issue and know how to fix it???
2012 Ford F-350 6.7L CC SRW w/FX4
2013 Forest River Sierra 365SAQ
Beausdog is offline   Reply With Quote
led pad
