Old 09-10-2012, 02:26 PM   #1
Converter Problem?
when I connect my battery cable to the battery post I hear a loud noise comming from the converter is this normal? It seems to take a long time for the power to come on so I can run the 12 volt lights lights.
toilet guy is offline   Reply With Quote
Old 09-10-2012, 02:28 PM   #2
TURBS's Avatar
Originally Posted by toilet guy
when I connect my battery cable to the battery post I hear a loud noise comming from the inverter is this normal? It seems to take a long time for the power to come on so I can run the lights.
Converter you mean ?
Lights are 12v not 110v .
Are you also hooked to shore power ?
Old 09-10-2012, 02:38 PM   #3
Converter Problem
Yes,
Converter not inverter.
Lights are 12 volt
Old 09-10-2012, 02:45 PM   #4
Herk7769's Avatar
How old is your battery?
If your battery is very weak it could lose it charge over time even with it disconnected from the trailer. When you first connect the battery the voltage is most likely too low to light the lights.
Connecting the Converter will allow it to TRY and charge that low (almost totally dead) battery. That will make a buzzing sound as it tries to bring the voltage up at its highest charge stage. If the battery were any lower it may not have worked at all. There is a safety circuit in the converter to prevent it from damaging itself from a shorted or dead battery.
After a few minutes, that battery will be charged enough to supply 10 or so volts and the current to light the lights bright enough for you to see.
IMO, you most likely need a new battery and some kind of battery maintainer to keep it healthy.
HAM CALLSIGN - KC3FFW
Old 09-10-2012, 02:47 PM   #5
TURBS's Avatar
I agree
