Old 12-01-2012, 09:09 AM   #1
converter problem
Hello everyone , this is my first post. This is also my first 5th wheel. We bought a 2010 Cardinal 3625 . When we went to pick it up they were changing out the converter , since weve been in it the past two months the battery does not hold a charge and the lights flicker. I just turned off the battery disconect while I was writing this and the gas alarm started going off. We love the camper , guess we have alot to learn. I found a piece of paper that has parallax on it in all our paper work. the converter in it is a INTEL-POWER 9200 series 60 amp converter / charger . ADVICE NEEDED
cjoel is offline   Reply With Quote
Old 12-01-2012, 09:52 AM   #2
rce
I'm no expert whatsoever and like you, new to my trailer and this forum. I had a sort of similar problem. Took my new to me TT in to get WD hitch installed. When I unplugged from house power propane alarm went off. If I turned outside light on (or off?) alarm stopped. Discovered later + battery cable was corroded right off the terminal & making sporadic contact at best. I also had been wondering why my 12 volt lighting wasn't working properly! Battery was toast too.
Anyway a wild guess is that the propane alarm sounds if it has no power source. Maybe has an internal rechargable battery to do so???
So I'm wondering if you have a bad battery and/or when you did the battery disconnect thing the alarm going off is normal? When you think of it that would be a very useful feature as if it loses all power and you don't know it and you have a gas leak that's bad!
With you I will wait for the real experts to answer your question.
rce is offline   Reply With Quote
Old 12-01-2012, 10:25 AM   #3
I just looked up a new Cardinal 3675 and it comes with a 70 amp converter, my 2010 3625 has only a 60 amp could this be the wrong converter .
Old 12-01-2012, 10:53 AM   #4
AquaMan's Avatar
This could be the right converter for your model. Newer models are always adding more electronics, thus the need for more power.
2016 Georgetown 364TS
2017 Jeep Rubicon Recon toad
Nights Camped 2018 - 7
Old 12-01-2012, 11:23 AM   #5
Dave_Monica's Avatar
As the camper had a faulty converter that had to be replaced, the battery has most likely been fully discharged in the past and is incapable of holding a charge. You could take it to a auto parts store and have it load-tested.
If the battery has already been replaced you need to check the voltage that the converter outputs. With some 12V lights/apps in use, the converter should be putting out at least 13.5V, which can be measured across the battery terminals. With the shorepower unplugged, a fully charged battery should measure around 12.7V.
Dave
Old 12-04-2012, 07:51 PM   #6
Im learning , it was a bad battery.
