Just picked up my new to me 2004 Sandpiper 32 RLSS yesterday and I'm having some electrical problems already. On shore power the 12 volt side was working and then would suddenly dim for a few seconds before going completely out. Power was still on the microwave. The converter fan would start up about 15 to 20 seconds prior to this happening. All of this was happening at the PO's permanent campsite. I replaced the house battery before pulling the thing home and it worked on the battery then but now that it's home I have nothing on the battery. Any insight would be greatly appreciated.
If the fan is starting up and running prior to the failure then the converter is working harder than it should and then shutting down. I would guess that tests for voltage would probably show correct but something else is up. The system doesn't need the battery in order to operate. I would disconnect the negative side of the battery, plug your rig in and see what happens. You can't rule out a bad battery or a short somewhere.
I have to admit this is one I have never seen so I'm taking a stab in the dark on it. Let us know what happens with the battery disconnected and the rig plugged in. Sounds like there is resistance somewhere where there shouldn't be to me.
"I can fix it, and if I can't fix it, I can fix it so no one can fix it!" Ed & Wendy 2009 Georgetown 378TS | 1998 Jeep Wrangler | 1998 Skeeter ZX202C
Nights camped in 2009: 53 | Nights camped in 2010: 55 www.nwjeepn.com
If you still have problems you may want to pull your fuses ( note where the 20 amp, 15 amp go & so on}. Then replace one at time to pin point problem. this is a easy way . no meters. Hope it helps.
2010 wildcat 31ts
05 Ford F350 SD PS
A friend had a problem and found that the ground wire was loose on the converter.
Jim and Jane
2008 Cardinal 30TS
Trail Air Pin Box, Center Point Suspension
Reese 18K hitch - Garmin 1690 GPS
2008 Chevy 2500HD 4x4 Duramax/Allison, Long Box, Smartair Nights camped in 2011: 120
Still don't quite understand the problem but I'm told by the service guy at the local Camping World that it was the switch just after the battery that was bad. I've had it hooked up to 20 amps, no 30 at home and it's seem to be working fine.
