Old 07-20-2016, 10:49 PM   #1
2006 Georgetown 340
Converter questions
I have been experiencing my batteries not holding a charge. I have a 2006 FR Georgetown 340 with the original WFCO 8865 converter. I upgraded to the Progressive Dynamics 9270 and the install seemed to go well. I connected the positive and negative wires and plugged it. My question is do I need to do anything else with this unit? How will I know if it is working any better?
The batteries the previous owner installed are sealed and I do not think I can add water. There is a plastic cover the could pop off but there is a Sulfuric Acid symbol on top and didn't think I should try it.
How can I tell if the batteries are damaged and need replaced?
Thanks in advance.
compint is offline   Reply With Quote
Old 07-21-2016, 04:59 AM   #2
ilmor's Avatar
Thanks in advance.
The plastic cover / warning is typical of batteries. You need to pop those off and inspect the water levels. Add only distilled. I'm guessing those batteries are in bad shape.
Also read this!!
The 12volt Side of Life (Part 1)
2017 Forest River Sunseeker 2250SLE
ilmor is offline   Reply With Quote
converter
